Snow
Senior Member
- Aug 1, 2014
Sorry about the wall of text ahead of time.
So I did the Update from 11.3-u5 to the new TrueNas 12.0 on my Primary server the X9 supermicro. For some reason I picked 12.0 but in ssh it shows 12.2-RC3. I am really excited about 12.0 and was looking forward to it! All the jails where not working, which is pretty normal. I did have to change devfs_ruleset on all my jails or they would not start. They were all set to 14 but one was 12. I seen a post that said to try 4 and they would run, that did work. At this point I'm not seeing any errors on the jails or Gui. I Then made sure all my other stuff was working, it was. So I went and upgraded the Pool's to 12.0. Cool no problems & no errors. I could worry about getting all my jails updated, upgraded & release upgrade later. Once I knew they where working on that release candidate. So I logged out for the night.
The Next day I new I was going to have to do some more work on the jails. So I decide to use my Couch Potato as my guinea pig. To see if I could upgrade or update them or if I would have to reinstall them. This is pretty common place or at least has been for me. Am I doing it wrong? So I logged in to the Gui, Then I moved over to the jails page, it took a very long time! So I clicked the dashboard it would not load. At this point I new I had Fracked up. Then I noticed the Gui pages where loading fast, but all the info was taking two to five minutes to load (oh no). No matter what I would click on in the Gui it did the same thing. Ssh was better then the gui.
Now on the Network & Local side of the jails it loads right away with no latency. Also having no problems on the SMB shares or speed issues. Last thing If I ssh in it takes like ten to fifteen sec to load the command line this is not normal. Any help would be great. The save debug in the Gui does not work. It will returns with the 2nd trace back below.
I tired to do a debug to see if I could get more Info, I got another Error with a Trace back.
Nov 16 20:39:52 freenas 1 2020-11-16T20:39:52.889159-06:00 #######.######.### collectd 4563 - - Traceback (most recent call last): File "/usr/local/lib/collectd_pyplugins/disktemp.py", line 62, in read with Client() as c: File "/usr/local/lib/python3.8/site-packages/middlewared/client/client.py", line 281, in __init__ self._ws.connect() File "/usr/local/lib/python3.8/site-packages/middlewared/client/client.py", line 124, in connect rv = super(WSClient, self).connect() File "/usr/local/lib/python3.8/site-packages/ws4py/client/__init__.py", line 223, in connect bytes = self.sock.recv(128) socket.timeout: timed out
Error: Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run await self.future File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 399, in __run_body rv = await self.middleware.run_in_thread(self.method, *([self] + args)) File "/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/system.py", line 787, in debug shutil.copyfileobj(f, job.pipes.output.w) File "/usr/local/lib/python3.8/shutil.py", line 205, in copyfileobj fdst_write(buf) BrokenPipeError: [Errno 32] Broken pipe
