Upgrade from 11.2-U7 to 11.3 (system + jails)
Pierce
Please read the docs and follow the directions on upgrading your jails from there.
https://iocage.readthedocs.io/en/latest/advanced-use.html#upgrading-jails
The correct command syntax is iocage upgrade dungeon -r 11.3-RELEASE
ok, THATS the right magic I was missing...
root@hognas:~ # iocage upgrade dungeon -r 11.3-RELEASE
src component not installed, skipped
Looking up update.FreeBSD.org mirrors... 3 mirrors found.
Fetching metadata signature for 11.2-RELEASE from update4.freebsd.org... done.
Fetching metadata index... done.
Fetching 1 metadata files... done.
Inspecting system... done.
The following components of FreeBSD seem to be installed:
world/base world/doc world/lib32
The following components of FreeBSD do not seem to be installed:
world/base-dbg world/lib32-dbg
Does this look reasonable (y/n)? y
Fetching metadata signature for 11.3-RELEASE from update4.freebsd.org... done.
Fetching 1 metadata patches. done.
Applying metadata patches... done.
Fetching files from 11.2-RELEASE for merging... done.
Preparing to download files... done.
Fetching 8206 patches.....10....20....30....40....50....60....70....80....90....100....110....120....130....140....150....160....170....180....190....200....210....220....230....240....250....260....270....280....290....300....310....320....330....340....350....360....370....380....390....400....410....420....430....440....450....460....470....480....490....500....510....520....530....540....550....560....570....580....590....600....610....620....630....640....650....660....670....680....690....700....710....720....730....740....750....760....770....780....790....800....810....820....830....840....850....860....870....880....890....900....910....920....930....940....950....960....970....980....990....1000....1010....1020....1030....1040....1050....1060....1070....1080....1090....1100....1110....1120....1130....1140....1150....1160....1170....1180....1190....1200....1210....1220....1230....1240....1250....1260....1270....1280....1290....1300....1310....1320....1330....1340....1350....1360....1370....1380....1390....1400....1410....1420....1430....1440....1450....1460....1470....1480....1490....1500....1510....1520....1530....1540....1550....1560....1570....1580....1590....1600....1610....1620....1630....1640....1650....1660....1670....1680....1690....1700....1710....1720....1730....1740....1750....1760....1770....1780....1790....1800....1810....1820....1830....1840....1850....1860....1870....1880....1890....1900....1910....1920....1930....1940....1950....1960....1970....1980....1990....2000....2010....2020....2030....2040....2050....2060....2070....2080....2090....2100....2110....2120....2130....2140....2150....2160....2170....2180....2190....2200....2210....2220....2230....2240....2250....2260....2270....2280....2290....2300....2310....2320....2330....2340....2350....2360....2370....2380....2390....2400....2410....2420....2430....2440....2450....2460....2470....2480....2490....2500....2510....2520....2530....2540....2550....2560....2570....2580....2590....2600....2610....2620....2630....2640....2650....2660....2670....2680....2690....2700....2710....2720....2730....2740....2750....2760....2770....2780....2790....2800....2810....2820....2830....2840....2850....2860....2870....2880....2890....2900....2910....2920....2930....2940....2950....2960....2970....2980....2990....3000....3010....3020....3030....3040....3050....3060....3070....3080....3090....3100....3110....3120....3130....3140....3150....3160....3170....3180....3190....3200....3210....3220....3230....3240....3250....3260....3270....3280....3290....3300....3310....3320....3330....3340....3350....3360....3370....3380....3390....3400....3410....3420....3430....3440....3450....3460....3470....3480....3490....3500....3510....3520....3530....3540....3550....3560....3570....3580....3590....3600....3610....3620....3630....3640....3650....3660....3670....3680....3690....3700....3710....3720....3730....3740....3750....3760....3770....3780....3790....3800....3810....3820....3830....3840....3850....3860....3870....3880....3890....3900....3910....3920....3930....3940....3950....3960....3970....3980....3990....4000....4010....4020....4030....4040....4050....4060....4070....4080....4090....4100....4110....4120....4130....4140....4150....4160....4170....4180....4190....4200....4210....4220....4230....4240....4250....4260....4270....4280....4290....4300....4310....4320....4330....4340....4350....4360....4370....4380....4390....4400....4410....4420....4430....4440....4450....4460....4470....4480....4490....4500....4510....4520....4530....4540....4550....4560....4570....4580....4590....4600....4610....4620....4630....4640....4650....4660....4670....4680....4690....4700....4710....4720....4730....4740....4750....4760....4770....4780....4790....4800....4810....4820....4830....4840....4850....4860....4870....4880....4890....4900....4910....4920....4930....4940....4950....4960....4970....4980....4990....5000....5010....5020....5030....5040....5050....5060....5070....5080....5090....5100....5110....5120....5130....5140....5150....5160....5170....5180....5190....5200....5210....5220....5230....5240....5250....5260....5270....5280....5290....5300....5310....5320....5330....5340....5350....5360....5370....5380....5390....5400....5410....5420....5430....5440....5450....5460....5470....5480....5490....5500....5510....5520....5530....5540....5550....5560....5570....5580....5590....5600....5610....5620....5630....5640....5650....5660....5670....5680....5690....5700....5710....5720....5730....5740....5750....5760....5770....5780....5790....5800....5810....5820....5830....5840....5850....5860....5870....5880....5890....5900....5910....5920....5930....5940....5950....5960....5970....5980....5990....6000....6010....6020....6030....6040....6050....6060....6070....6080....6090....6100....6110....6120....6130....6140....6150....6160....6170....6180....6190....6200....6210....6220....6230....6240....6250....6260....6270....6280....6290....6300....6310....6320....6330....6340....6350....6360....6370....6380....6390....6400....6410....6420....6430....6440....6450....6460....6470....6480....6490....6500....6510....6520....6530....6540....6550....6560....6570....6580....6590....6600....6610....6620....6630....6640....6650....6660....6670....6680....6690....6700....6710....6720....6730....6740....6750....6760....6770....6780....6790....6800....6810....6820....6830....6840....6850....6860....6870....6880....6890....6900....6910....6920....6930....6940....6950....6960....6970....6980....6990....7000....7010....7020....7030....7040....7050....7060....7070....7080....7090....7100....7110....7120....7130....7140....7150....7160....7170....7180....7190....7200....7210....7220....7230....7240....7250....7260....7270....7280....7290....7300....7310....7320....7330....7340....7350....7360....7370....7380....7390....7400....7410....7420....7430....7440....7450....7460....7470....7480....7490....7500....7510....7520....7530....7540....7550....7560....7570....7580....7590....7600....7610....7620....7630....7640....7650....7660....7670....7680....7690....7700....7710....7720....7730....7740....7750....7760....7770....7780....7790....7800....7810....7820....7830....7840....7850....7860....7870....7880....7890....7900....7910....7920....7930....7940....7950....7960....7970....7980....7990....8000....8010....8020....8030....8040....8050....8060....8070....8080....8090....8100....8110....8120....8130....8140....8150....8160....8170....8180....8190....8200... done.
Applying patches...
and still running...
Jailer
Not strong, but bad
It will take a little while.
Pierce
Me thinks the Web UI for jails, 'update' should have an option to select the current release instead of the jails original release...
Jailer
Not strong, but bad
That update button has a different function. It updates the patch level of the current FreeBSD base system in the jail.
Jailer
Not strong, but bad
Pimmp
Yeah, because you didn't read my post directly above yours.
root@freenas:~ # iocage upgrade plex_2 -r 11.3-RELEASE
Snapshotting plex_2...
Snapshot already exists
Updating plugin INDEX...
/mnt/PlexJail/iocage/jails/plex/plex.json was not found!
root@freenas:~ #
Pimmp
Does this directory exist? /mnt/PlexJail/iocage/jails/plex
Nope, it is /mnt/PlexJail/iocage/jails/plex_2
but i am asking for upgrade plex_2-> iocage upgrade plex_2 -r 11.3-RELEASE
Dont know what´s pointing to plex ?
SweetAndLow
Sweet'NASty
don't know what´s pointing to plex ?
Did you rename the jail in the past? Try just renaming it.
Pimmp
No i did not, I had the original server running under Freenas 9, deleted it and installed iocage jail instead.
Guess that´s why Plex_2.
I renamed it to plex and tried to upgrade it.
Error updating repositories!
root@freenas:~ # iocage list
| JID | NAME | STATE | RELEASE | IP4 |
| 5 | plex | up | 11.2-RELEASE | 192.168.0.3 |
| 2 | unifi | up | 11.3-RELEASE | 192.168.0.4 |
root@freenas:~ # iocage upgrade plex -r 11.3-RELEASE
Snapshotting plex...
File "/usr/local/bin/iocage", line 10, in <module>
sys.exit(cli())
File "/usr/local/lib/python3.7/site-packages/click/core.py", line 764, in __call__
return self.main(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/click/core.py", line 717, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python3.7/site-packages/click/core.py", line 1137, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/local/lib/python3.7/site-packages/click/core.py", line 956, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/local/lib/python3.7/site-packages/click/core.py", line 555, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/iocage_cli/upgrade.py", line 40,in cli
ioc.IOCage(jail=jail, skip_jails=skip_jails).upgrade(release)
File "/usr/local/lib/python3.7/site-packages/iocage_lib/iocage.py", line 2065, in upgrade
).upgrade(jid)
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 1271, in upgrade
self.iocroot, 'jails', self.jail, f'{plugin_name}.json
