qwertymodo
- Apr 7, 2014
Ok, cool. That makes sense, since FreeNAS 10 is pretty much going to break plugin upgrades anyway, from what I understand.
It would be nice if you could include the redis binaries as well, it's a real pain to install applications inside of a plugin without access to ports or most of the necessary build tools for a source install.I could add the redis php extension, but it'd be up to a user to install and enable redis, and configure their config.php.
you can just install it to the jail, not sure how that's hard?It would be nice if you could include the redis binaries as well, it's a real pain to install applications inside of a plugin without access to ports or most of the necessary build tools for a source install.
it's not as straight forward to install the php modules, to the php the plugin uses. that's why they'd need to be bundled with the plugin.Hmm... there are php-redis modules for 5.5 and 5.6 available in pkg, but none for 5.4. Oh well...
The plugin update mechanism just replaces the application files with the latest ones. It is still needed to use 'occ' to upgrade the database.Hello, I have the Problem with 9.0.3 update. According to the message after calling ownCloud web page it is permanently in Maintenance Mode.
Can this also be solved by using command interface?
Update was done by using the button in freeNAS.
Thanks!
su -m www -c '/usr/pbi/owncloud-amd64/bin/php /usr/pbi/owncloud-amd64/www/owncloud/occ upgrade'
