In FreeNAS through GUI I installed OwnCloud as a jail. Everything works ok. The installation and OwnCloud itself. When I login to OwnCloud I get notice that I should upgrade to OwnCloud 8.2 and that I also run php 5.4 which should also be upgraded.
If I manually upgrade to latest OwnCloud and latest php (7.0.2), how will this affect the option that I can also update/upgrade the OwnCloud instance through FreeNAS GUI - when it is available? Can I upgrade php and that FreeNAS GUI update feature will also work?
