unreadable (pending) sectors
Caffe Mocha
Hello ,
One day, my freenas alert just pop up the warning message below.
Device: /dev/ada4, 2 Currently unreadable (pending) sectors
I have tried Smartctl (long test )and scrub. no errors were found and scrub came out clean without repairs.
If you could be so kind provide me with some suggestion as to potential or actual problems (hardware problems) or if it's just a false alarm. and the solution for it
Thanks a bunch
Smartctl results are below
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 166 155 021 Pre-fail Always - 6683
4 Start_Stop_Count 0x0032 094 094 000 Old_age Always - 6208
5Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 076 076 000 Old_age Always - 17585
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 097 097 000 Old_age Always - 3319
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 495
193 Load_Cycle_Count 0x0032 111 111 000 Old_age Always - 267000
194 Temperature_Celsius 0x0022 121 097 000 Old_age Always - 29
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 2
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 10
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 17553 -
# 2 Extended offline Completed without error 00% 17524 -
# 3 Extended offline Completed without error 00% 14226 -
# 4 Short offline Completed without error 00% 14219 -
# 5 Extended offline Completed without error 00% 14136 -
DrKK
FreeNAS Generalissimo
This is the second time I've heard of this, unless you have posted two times?
Caffe Mocha
There was a same post of the same problem but that wasn't me.
I am hoping if someone could take a look at smartctl result for me to see if it actually is a a hard disk related issue .
BigDave
FreeNAS Enthusiast
Some observations in no order of importance:
Self test list has large gaps (self tests performed too infrequently)
193 Load_Cycle_Count (seems a bit high @ 276,000) based on:
The above results would be cause for concern so I would recommend to set
up smart tests @ once per week and keep an eye on these and other numbers.
If the numbers begin to increase, it's time to replace the drive.
https://kb.acronis.com/content/9133
DrKK
Yeah I agree, any number but "0" in attribute 197 or 200 is a cause for concern.
There is a chance (say, 1 in 4?) that this will not get any worse, and the hard drive will remap the sectors, and you can move forward. However, I will tell you this: 98% of us would immediately RMA a drive that showed positive numbers in 197 or 200.
Caffe Mocha
Thanks, in that case, I will RMA the drive before warranty expires . Thanks again
joeschmuck
Old Man
Such a low number, it should be 100% but some folks would hold on to a drive and hope for the best.
