Currently unreadable (pending) sectors - Extended offline Completed without error
jFlatz
I'm a bit lost here. I'm getting
Device: /dev/ada4, 1 Currently unreadable (pending) sectors
So I ran a Long SMART test and followed it up with a Scrub of my volume. I've done this twice now and I'm still being told there is unreadable sectors.
Model Family:  Western Digital Caviar Green (AF)
Device Model:  WDC WD20EARS-00MVWB0
LU WWN Device Id: 5 0014ee 0024bb23d
Firmware Version: 50.0AB50
User Capacity:  2,000,398,934,016 bytes [2.00 TB]
Sector Size:  512 bytes logical/physical
Device is:  In smartctl database [for details use: -P show]
ATA Version is:  ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:  Fri Apr 28 10:14:29 2017 UTC
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
  was suspended by an interrupting command from host.
Self-test execution status:  (  0) The previous self-test routine completed
  been run.
data collection:  (38400) seconds.
capabilities:  (0x7b) SMART execute Offline immediate.
  command.
  Self-test supported.
SMART capabilities:  (0x0003) Saves SMART data before entering
  power-saving mode.
Error logging capability:  (0x01) Error logging supported.
Short self-test routine
recommended polling time:  (  2) minutes.
Extended self-test routine
recommended polling time:  ( 437) minutes.
Conveyance self-test routine
recommended polling time:  (  5) minutes.
SCT capabilities:  (0x3035) SCT Status supported.
  SCT Data Table supported.
ID# ATTRIBUTE_NAME  FLAG  VALUE WORST THRESH TYPE  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate  0x002f  200  200  051  Pre-fail  Always  -  0
  3 Spin_Up_Time  0x0027  156  155  021  Pre-fail  Always  -  7158
  4 Start_Stop_Count  0x0032  100  100  000  Old_age  Always  -  681
  5 Reallocated_Sector_Ct  0x0033  200  200  140  Pre-fail  Always  -  0
  7 Seek_Error_Rate  0x002e  200  200  000  Old_age  Always  -  0
  9 Power_On_Hours  0x0032  099  099  000  Old_age  Always  -  1337
 10 Spin_Retry_Count  0x0032  100  100  000  Old_age  Always  -  0
 11 Calibration_Retry_Count 0x0032  100  100  000  Old_age  Always  -  0
 12 Power_Cycle_Count  0x0032  100  100  000  Old_age  Always  -  555
192 Power-Off_Retract_Count 0x0032  200  200  000  Old_age  Always  -  140
193 Load_Cycle_Count  0x0032  183  183  000  Old_age  Always  -  51284
194 Temperature_Celsius  0x0022  120  098  000  Old_age  Always  -  30
196 Reallocated_Event_Count 0x0032  200  200  000  Old_age  Always  -  0
197 Current_Pending_Sector  0x0032  200  200  000  Old_age  Always  -  1
198 Offline_Uncorrectable  0x0030  200  200  000  Old_age  Offline  -  0
199 UDMA_CRC_Error_Count  0x0032  200  200  000  Old_age  Always  -  0
200 Multi_Zone_Error_Rate  0x0008  200  200  000  Old_age  Offline  -  9
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description  Status  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline  Completed without error  00%  1333  -
# 2  Extended offline  Completed without error  00%  1322  -
# 3  Extended offline  Completed without error  00%  900  -
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
m0nkey_
This is an early indicator of a failing drive. If the count increases, you will want to replace it sooner rather than later.
Dice
jFlatz
Thanks dice I'll take a look at that tonight!
