Possible Bad Drive?
HumbleTechie
I need some assistance reading logs from tests. I noticed this error as a critical alert in FreeNAS:
Device: /dev/ada0, 1 Currently unreadable (pending) sectors
Current setup:
3x2TB WD Red
zpool status
  pool: Primary_Storage
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
		still be used, but some features are unavailable.
  scan: scrub repaired 0 in 3h10m with 0 errors on Sun Apr  2 03:10:47 2017
		NAME											STATE	 READ WRITE CKSUM
		Primary_Storage								 ONLINE	   0	 0	 0
		  raidz1-0									  ONLINE	   0	 0	 0
			gptid/8f5428f2-6e04-11e4-b897-448a5bce7ef7  ONLINE	   0	 0	 0
			gptid/90084381-6e04-11e4-b897-448a5bce7ef7  ONLINE	   0	 0	 0
			gptid/90ba66f0-6e04-11e4-b897-448a5bce7ef7  ONLINE	   0	 0	 0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0h1m with 0 errors on Sun Apr  2 03:46:01 2017
		freenas-boot  ONLINE	   0	 0	 0
		  da0p2	 ONLINE	   0	 0	 0
After running smart long test on ada0:
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(26100) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 264) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x703d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   9
  3 Spin_Up_Time			0x0027   172   172   021	Pre-fail  Always	   -	   4400
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   32
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   072   072   000	Old_age   Always	   -	   20642
10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   32
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   22
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   210
194 Temperature_Celsius	 0x0022   119   112   000	Old_age   Always	   -	   28
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
-- > 197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   1
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   8
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	 20589		 -
# 2  Extended offline	Completed without error	   00%	 20575		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
It seems as though everything is passing except the 1 pending sector?
Is this enough to RMA the drive?
joeschmuck
Old Man
Run a SMART Long test onthe drive and see if the problem is still there.
Even if the problem remains, this is not terrible just yet. You also have IS 200 MultiZone Errors which you should keep an eye on.
Technically it's enough to RMA the drive however I'd run the long test first. If the problem clears then you will be fine for now. If your drive is near the end of the 3 year warranty then I'd RMA it. If you got more than 6-8 months left then I'd wait unless you start getting more errors.
I take it that you do not run routine SMART tests on your drives. My advice, run a daily SMART Short test and weekly SMART long test on all your drives.
SweetAndLow
Sweet'NASty
Setup smart tests to run automatically. Don't worry about the pending sector yet
DrKK
FreeNAS Generalissimo
Now, I'm ultra-hard-core, I pull the panic button much much earlier than most people. But if I have pending sector(s) *and* multi-zone errors (you have 8 of them, apparently), then I consider the drive toast.
Just another view.
Speaking for a statistical standpoint, there is a decent chance your drive will still provide ample service moving forward, especially if after a SMART LONG test that you kick off if nothing gets worse.
joeschmuck
Old Man
I wouldn't say that is true. I think you are more laid back than that, but you have a valid point.
HumbleTechie
Thanks for the information all.
Should I re-run a long smart test and post results? The last one I ran was Sunday, and I was still getting the 1 pending sector error after that.
I have also setup automatic tests going forward.
joeschmuck
Old Man
I say run the test now and maybe the error goes away but don't hold your breath. Feel free to post the data if you like but if you haven't already done so, check out the link in my signature and you can see what IDs are important to look at. If you would feel better sending the drive in for RMA, then do it. You can also perform an Advance RMA where WD will ship you a new-to-you drive (you need to secure it on a credit card) and then when you get the new drive, you swap it out and now you have a return box as well, and the last time I did it the return was paid for. Nothing gets charged to your credit card if you return the failed drive within a certain period of time.
HumbleTechie
Thanks for the great suggestion. I will most likely go this route as the warranty expires later this year.
The long test finished. I'm still seeing 1 pending sector error, but the Multi_Zone_Error_Rate dropped down to 3 (not sure if that makes any difference). Everything else is the same.
joeschmuck
Old Man
You will likely see the pending sector error until that location on the hard drive is written over again. The Multi zone errors dropping is good.
Since you are nearing the end of the warranty period, I'd consider doing the advanced RMA. Typically having a pending sector error will eventually lead to having more and worse errors.
