TL;DR was attempting to upgrade from FreeNAS 10 to 11 and the upgrade appears to have failed. I grabbed the latest ISO from the FreeNAS site and burned it using both ImageWriter and Rufus. Regardless, the outcome remains the same. I did the command set xhci_load=YES and still no luck. See link for output. I should also note that I'm only trying to upgrade from USB (via console) because I can no longer access the GUI because of the failed upgrade.
https://imgur.com/a/9izlUcs
