Hi all,
First of all, please excuse my English as it is my main language. Second, thank you all for TrueNAS software. I'm quite newbie with it but I would like to comment an issue I've found with my system. I'm not use to reaise bugs or whatever and I'm not sure even if I could be facing one (although it seems to me) so I really appreciate your comments/suggestions.
The problem: Both in TrueNAS SCALE 21.02 and 21.04 (alpha stage, I know) when I power off my system ("poweroff", "shutdown -h now", "init 0" commands into SSH, or by clicking into the web GUI button) the system poweroff (ok) but a few seconds after, it turns on again by itself (bad).
Checked the BIOS there is no wake-on-lan option enabled. In fact, BIOS is really quite simple and there is no much room to touch anything on it (besides EuP which has been tested enabled and disabled with the same result).
I've tested with Debian 10.9 and Debian 11 (RC) with the same result. And searching at forums it seems an issue related with ACPI tables or whatever but I don't get any solution for that.
Funny thing is TrueNAS Core 12.0-U3 works flawlessly: you click shutdown and it goes down and stays down. I know the core of both platforms are different (Linux vs FreeBSD) so it probably explains the different behavior but... as you iXSystem develops both solutions, do you think I should raise a bug case regarding TrueNAS SCALE? Or maybe someone else faced this issue and can provide some guidance to tweak files or configurations? (as said, I'm afraid BIOS hasn't room for more checks)
My system is an old QNAP TS-451 NAS (J1800 + 8GB RAM) and I'm trying to replace its QTS SO with TrueNAS. I've seen I could choose TrueNAS CORE but with TrueNAS SCALE development near beta stage I would like to know if there is something to do with this issue and stay on SCALE/Debian.
Thank you all in advance for your reading and, for sure, your suggestions.
