Time to replace HDD?
bbolgar
Hi all,
TrueNas reports from time to time, that /dev/ada1 is unreachable, due to Current_Pending_Sector and Offline_Uncorrectable errors on it. All checks come back successful, the pool status is online - question is, do I need to replace this disk ASAP, or I should wait till it really fails?
Checks:
smartctl -a /dev/ada1
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p2 amd64] (local build)
Model Family:     Seagate Barracuda Green (AF)
Device Model:     ST2000DL003-9VT166
Serial Number:    5YD6FA7H
LU WWN Device Id: 5 000c50 04628a645
Firmware Version: CC3C
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Rotation Rate:    5900 rpm
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Dec  3 17:45:24 2022 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  623) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 338) minutes.
Conveyance self-test routine
SCT capabilities:              (0x30b7) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   108   099   006    Pre-fail  Always       -       18977536
  3 Spin_Up_Time            0x0003   093   091   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       674
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   088   060   030    Pre-fail  Always       -       688111789
  9 Power_On_Hours          0x0032   081   081   000    Old_age   Always       -       17444
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       299
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   080   080   000    Old_age   Always       -       20
188 Command_Timeout         0x0032   100   098   000    Old_age   Always       -       6
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   062   046   045    Old_age   Always       -       38 (Min/Max 36/40)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       46
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       979
194 Temperature_Celsius     0x0022   038   054   000    Old_age   Always       -       38 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   031   003   000    Old_age   Always       -       18977536
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       40
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       40
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       11686 (136 224 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       3373103005
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       2053614134
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     17444         -
# 2  Short offline       Completed without error       00%     17421         -
# 3  Extended offline    Completed without error       00%     17236         -
zpool status -v
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:09 with 0 errors on Tue Nov 29 03:45:09 2022
          ada0p2    ONLINE       0     0     0
errors: No known data errors
  pool: default
 state: ONLINE
        default                                         ONLINE       0     0     0
          mirror-0                                      ONLINE       0     0     0
            gptid/6fcaa62c-5f86-11ed-9a9a-bcaec58adf3b  ONLINE       0     0     0
            gptid/6fdbd184-5f86-11ed-9a9a-bcaec58adf3b  ONLINE       0     0     0
Thanks in advance for the advices!
Pitfrr
Well, I would definitely test this drive thoroughly:
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 40 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 40
because this is concerning...
The long smart test doesn't seem to have reported any error... but I would run a badblock (destructive) on this drive to make sure of it.
If it turns out good, I would still look into changing the drive (and maybe use it for backups) or keep a very closed eye on it... Of course this also depends on the data on it and how much you value that data... :smile:
Don't know much about this one what it exactly means but doesn't sound so good... Seems it is not a critical one but could indicate some problems... I would say in combination with #197 and #198, that doesn't look good.
I would make sure all your backups are good... and then test the drive thoroughly.
Also: it would be good for the future to plan regular SMART tests (long and short), because this drive didn't see any until recently only.
bbolgar
Thanks for the quick response on this - I have enabled long & short tests today when I saw this error. Also, the NAS has been set up a few weeks ago only, that might explain why there are only recent tests ;)
Davvo
Pitfrr
This means the drives are used one, right.
Because the details of the one you posted shows +17k hours, so that's about 2 years.
Anyway, a good practice is to do some burn in of the drives before using them (doesn't matter if new of used).
Matt_G
Personally, I would replace that drive right now.
40 current pending sectors is totally unacceptable to me.
I value my data too much to trust a drive in that condition any longer.
