sdgenxr
- Sep 4, 2014
Last week I received the dreaded alert that one of my drives has an unrecoverable error. Prior to replacing the drive (sde), I decided to view the details of all the SMART tests (below). Now I'm wondering if I should just replace the entire pool, or can I get away with replacing sde now, and the pool in the next few months?
[HIDE]root@server[~]# smartctl -a /dev/sde
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.131+truenas] (local build)
Model Family: Hitachi/HGST Deskstar 5K4000
Device Model: HGST HDS5C4040ALE630
Serial Number: PL2331LAGHBS9J
LU WWN Device Id: 5 000cca 22ec6fdae
Firmware Version: MPAOA580
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5700 rpm
Form Factor: 3.5 inches
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Oct 8 17:18:48 2022 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
been run.
data collection: ( 28) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 717) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 134 134 054 Pre-fail Offline - 102
3 Spin_Up_Time 0x0007 135 135 024 Pre-fail Always - 522 (Average 512)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 333
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 113 113 020 Pre-fail Offline - 42
9 Power_On_Hours 0x0012 092 092 000 Old_age Always - 61022
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 331
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2132
193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2132
194 Temperature_Celsius 0x0002 157 157 000 Old_age Always - 38 (Min/Max 19/52)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 60963 -
# 2 Extended offline Completed without error 00% 60940 -
# 3 Short offline Completed without error 00% 60928 -
# 4 Extended offline Completed without error 00% 7432 -
# 5 Extended offline Interrupted (host reset) 90% 7419 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@server[~]# smartctl -a /dev/sdc
Serial Number: PL1311LAG0PZRA
LU WWN Device Id: 5 000cca 22ec0528d
Local Time is: Sat Oct 8 17:20:22 2022 PDT
was never started.
been run.
command.
power-saving mode.
recommended polling time: ( 738) minutes.
2 Throughput_Performance 0x0005 135 135 054 Pre-fail Offline - 98
3 Spin_Up_Time 0x0007 141 141 024 Pre-fail Always - 473 (Average 518)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 326
9 Power_On_Hours 0x0012 092 092 000 Old_age Always - 61017
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 326
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2235
193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2235
194 Temperature_Celsius 0x0002 162 162 000 Old_age Always - 37 (Min/Max 19/51)
No Errors Logged
# 1 Extended offline Completed without error 00% 60936 -
# 2 Short offline Completed without error 00% 60923 -
# 3 Extended offline Completed without error 00% 7428 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@server[~]# smartctl -a /dev/sdd
Serial Number: PL1331LAG61ABH
LU WWN Device Id: 5 000cca 22ec2bf3c
Local Time is: Sat Oct 8 17:20:34 2022 PDT
was never started.
been run.
command.
power-saving mode.
recommended polling time: ( 741) minutes.
2 Throughput_Performance 0x0005 135 135 054 Pre-fail Offline - 99
3 Spin_Up_Time 0x0007 141 141 024 Pre-fail Always - 472 (Average 515)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 336
9 Power_On_Hours 0x0012 092 092 000 Old_age Always - 61037
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 332
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2126
193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2126
194 Temperature_Celsius 0x0002 162 162 000 Old_age Always - 37 (Min/Max 20/51)
No Errors Logged
# 1 Extended offline Completed without error 00% 60955 -
# 2 Short offline Completed without error 00% 60942 -
# 3 Extended offline Completed without error 00% 7448 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@server[~]# smartctl -a /dev/sdf
Serial Number: PL1310LAG0HHTA
LU WWN Device Id: 5 000cca 22ec03a38
Local Time is: Sat Oct 8 17:20:43 2022 PDT
was never started.
been run.
command.
power-saving mode.
recommended polling time: ( 732) minutes.
3 Spin_Up_Time 0x0007 137 137 024 Pre-fail Always - 514 (Average 501)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 343
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 74
9 Power_On_Hours 0x0012 092 092 000 Old_age Always - 61026
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 342
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2030
193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2030
194 Temperature_Celsius 0x0002 153 153 000 Old_age Always - 39 (Min/Max 19/53)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 75
No Errors Logged
# 1 Extended offline Completed without error 00% 60945 -
# 2 Short offline Completed without error 00% 60932 -
# 3 Extended offline Completed without error 00% 30030 -
# 4 Extended offline Completed without error 00% 29311 -
# 5 Extended offline Completed without error 00% 28568 -
# 6 Extended offline Completed without error 00% 28199 -
# 7 Short offline Completed without error 00% 28114 -
# 8 Short offline Completed without error 00% 27946 -
# 9 Short offline Completed without error 00% 27778 -
#10 Short offline Completed without error 00% 27610 -
#11 Extended offline Completed without error 00% 27455 -
#12 Short offline Completed without error 00% 27442 -
#13 Extended offline Completed without error 00% 26711 -
#14 Extended offline Completed without error 00% 25990 -
#15 Extended offline Completed without error 00% 25283 -
#16 Extended offline Completed without error 00% 24544 -
#17 Extended offline Completed without error 00% 23807 -
#18 Extended offline Completed without error 00% 23080 -
#19 Extended offline Completed without error 00% 22360 -
#20 Short offline Completed without error 00% 22275 -
#21 Short offline Completed without error 00% 22107 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
