New Hard drive causes degraded pool
JMuff
Replaced a faulted hard drive a few days ago with a new WD red 4TB and it instantly gave write errors during the first resilvering. I went through the usual troubleshooting (Following https://www.truenas.com/community/r...ubleshooting-guide-all-versions-of-freenas.17), and wanted soem advice on what to do next.
Output from `zpool status -v`
 root@truenas[~]# zpool status -v
  pool: Data1
 state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
        Sufficient replicas exist for the pool to continue functioning in a
        degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
        repaired.
  scan: resilvered 200G in 03:13:13 with 0 errors on Fri Sep 30 11:37:07 2022
        NAME                                      STATE     READ WRITE CKSUM
        Data1                                     DEGRADED     0     0     0
          raidz1-0                                DEGRADED     0     0     0
            f514485f-c6e0-4317-984c-25a1ecaf4645  ONLINE       0     0     0
            21e09f5f-a64f-479c-8fe5-19c5be56c8b3  ONLINE       0     0     0
            0a5a59a2-a8a0-4339-a00b-d53644064a13  ONLINE       0     0     0
            28d756a5-df1d-468b-b338-09382ebf33e1  FAULTED      0    12     2  too many errors
errors: No known data errors
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:34 with 0 errors on Mon Sep 26 03:45:36 2022
          sda3      ONLINE       0     0     0
As you can see it's 4x4TB in raidz1. After seating the new hard drive I tried the following:
  • Replacing SATA cable
  • Changing SATA port on MB
  • Reseating the hard drive and moving the hard drive to another location in the chassis
  • Using a different power cable form power supply
  • Removing a mirror ssd from the boot pool because maybe there were too many devices for the onboard SATA controller
Each time I did the above I resilvered the entire pool and errors were persistent.
Here is the output from a long smartctl test
root@truenas[~]# smartctl -a /dev/sdc
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.142+truenas] (local build)
Model Family:     Western Digital Red (SMR)
Device Model:     WDC WD40EFAX-68JH4N1
Serial Number:    WD-WX22D523C9Y3
LU WWN Device Id: 5 0014ee 215462e7a
Firmware Version: 83.00A83
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
TRIM Command:     Available, deterministic, zeroed
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Sep 30 16:34:35 2022 EEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (18600) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 100) minutes.
Conveyance self-test routine
recommended polling time:        (   3) minutes.
SCT capabilities:              (0x3039) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   100   253   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   202   201   021    Pre-fail  Always       -       2858
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       52
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       56
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       51
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       43
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       8
194 Temperature_Celsius     0x0022   114   108   000    Old_age   Always       -       33
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%        40         -
# 2  Extended offline    Completed without error       00%        38         -
# 3  Short offline       Completed without error       00%         4         -
Everything I've read indicates that this is a DOA HDD. However I have some suspicions. The previous "Faulted" hard drive that I replaced wasn't exactly old. It was manufactured in 2019 and SMART tests indicated that the hard drive wasn't exactly pre failure. Is this potentially some bug in trunas or zfs on my installation?
Also, what recommendations do you have for a DOA HDD? I can return through amazon but the hard drive already has my data on. Otherwise I can go through WD. Any success going through the manufacturer?
root@truenas[~]# smartctl -a /dev/sde
Device Model:     WDC WD40EFRX-68N32N0
Serial Number:    WD-WCC7K1PCL2FV
LU WWN Device Id: 5 0014ee 266a6c569
Firmware Version: 82.00A82
Local Time is:    Fri Sep 30 16:39:39 2022 EEST
                                        was never started.
                                        been run.
data collection:                (42120) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 447) minutes.
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303d) SCT Status supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   212   164   021    Pre-fail  Always       -       4375
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       822
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   077   077   000    Old_age   Always       -       17349
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       772
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       57
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       782
194 Temperature_Celsius     0x0022   112   106   000    Old_age   Always       -       38
No Errors Logged
# 1  Short offline       Completed without error       00%     17333         -
# 2  Short offline       Completed without error       00%     17304         -
# 3  Short offline       Completed without error       00%     17278         -
# 4  Short offline       Completed without error       00%     17254         -
# 5  Short offline       Completed without error       00%     17229         -
# 6  Short offline       Completed without error       00%     17206         -
# 7  Short offline       Completed without error       00%     17181         -
# 8  Short offline       Completed without error       00%     17158         -
# 9  Short offline       Completed without error       00%     17134         -
#10  Short offline       Completed without error       00%     17110         -
#11  Short offline       Completed without error       00%     17086         -
#12  Short offline       Completed without error       00%     17062         -
#13  Short offline       Completed without error       00%     17039         -
#14  Short offline       Completed without error       00%     17015         -
#15  Short offline       Completed without error       00%     16991         -
#16  Short offline       Completed without error       00%     16967         -
#17  Short offline       Completed without error       00%     16943         -
#18  Short offline       Completed without error       00%     16919         -
#19  Short offline       Completed without error       00%     16895         -
#20  Short offline       Completed without error       00%     16871         -
#21  Short offline       Completed without error       00%     16847         -
Thanks as always for help!
jgreco
Resident Grinch
I believe that 2019-era WD Red 4TB's are SMR drives. If so, replace the drive, it isn't ZFS compatible.
Yup, smartmontools agrees:
joeschmuck
Old Man
Today I learned! Thanks a lot!
Don't worry, we all learn, and typically it's a hard lesson. SMR has got a lot of people.
