Hi everyone:
About a year and some ago I installed my 1st Truenas Core server, I experimented virtualizing it over ESXi (with ECC memory and the such) and so far it's been working steady with no issues. I passthrough a Supermicro AOC-S3008L-L8e with the latest firmware (from Supermicro) and created a pool with 2x RAIDZ2 vdevs, 4x4TB and 4x6TB drives. Scrubs and SMART checks performed regularly with no issues. I have been doing the software updates with no issues, performance is good and all that.
Now, I need to add storage to my pool so I decided to replace the 4x4TB vdev with 12TB drives, as you all know there are two methods for this. The preferred method were you replace the disk without degrading the pool and the other method were you actually take the disk offline to do so all this is detailed here:
Since I don't want to degrade the pool I wanted to proceed with the replace method. I do have a RES2SV240 Intel expander, and I added the expander connecting it to the AOC-S3008L-L8e HBA controller, leaving 4 drives in the HBA and 4 drives in the expander. When Truenas comes back online it detects all the drives connected to the expander and only ONE (1) drive connected to the HBA, which is odd.
I decided then to remove the expander and add a second HBA AOC-S3008L-L8e (same firmware) I purchased as spare connecting 4 drives (1 vdev) to each card, passthrough the card to ESXi and Truenas boot in degraded state as the last drive da8 on the pool is detected but with errors.
All I'm trying to do is to be able to see 9 drives so I can start replacing the 4TB's by 12TBs
I wonder if aside of ESXi and virtualized Core not being supported and these issues could perfectly be due to the virt environment if anyone has any previous experience like this.
At some point in the future I will have a baremetal system but for now this will have to do.
I'm currently backing up the entire contents so I can destroy the pool and re create it with the new drives but replacing and resilvering would be great to have
Thank you in advance for any answers.
9. Storage — FreeNAS®11.2-U5 User Guide Table of Contents
www.ixsystems.com
