Hi.
Patrick thanks for you input so far!
For the sake of not posting the info of all 24 drives I chose 3. The one on the degraded pool, the new drive on the degraded pool and just to compare another drive on non-degraded pool. I don't really know what to make of this:
A drive on degraded pool:
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p10 amd64] (local build)
Model Family: Seagate Exos X16
Device Model: ST16000NM001G-2KK103
Serial Number:
LU WWN Device Id: 5 000c50 0c394a89e
Firmware Version: SN02
User Capacity: 16,000,900,661,248 bytes [16.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Dec 22 16:04:51 2021 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 567) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1454) minutes.
Conveyance self-test routine
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 083 064 044 Pre-fail Always - 220629896
3 Spin_Up_Time 0x0003 092 090 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 26
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 087 060 045 Pre-fail Always - 447378427
9 Power_On_Hours 0x0032 082 082 000 Old_age Always - 16171
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 26
18 Head_Health 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 073 061 040 Old_age Always - 27 (Min/Max 18/33)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 19
193 Load_Cycle_Count 0x0032 099 099 000 Old_age Always - 2959
194 Temperature_Celsius 0x0022 027 040 000 Old_age Always - 27 (0 18 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Pressure_Limit 0x0023 100 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 15924h+21m+51.364s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 40050761450
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 443504785843
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
New drive on degraded pool:
Serial Number:
LU WWN Device Id: 5 000c50 0dbc2d860
Firmware Version: SN03
Local Time is: Wed Dec 22 16:04:08 2021 CET
been run.
command.
power-saving mode.
recommended polling time: (1376) minutes.
1 Raw_Read_Error_Rate 0x000f 079 064 044 Pre-fail Always - 78933488
3 Spin_Up_Time 0x0003 098 098 000 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 075 060 045 Pre-fail Always - 30391766
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 145
190 Airflow_Temperature_Cel 0x0022 071 049 040 Old_age Always - 29 (Min/Max 19/35)
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 20
194 Temperature_Celsius 0x0022 029 040 000 Old_age Always - 29 (0 19 0 0 0)
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 144h+28m+09.165s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 24010867338
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 31255774946
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Drive on a normally-working pool:
Serial Number:
LU WWN Device Id: 5 000c50 0c3b3adf9
Local Time is: Wed Dec 22 16:05:40 2021 CET
been run.
command.
power-saving mode.
recommended polling time: (1428) minutes.
1 Raw_Read_Error_Rate 0x000f 082 064 044 Pre-fail Always - 152009029
3 Spin_Up_Time 0x0003 091 090 000 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 080 060 045 Pre-fail Always - 91967712
190 Airflow_Temperature_Cel 0x0022 072 049 040 Old_age Always - 28 (Min/Max 20/33)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 16
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 266575
194 Temperature_Celsius 0x0022 028 040 000 Old_age Always - 28 (0 19 0 0 0)
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 2374h+40m+40.512s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 17966674082
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 98162208316
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
