el_reddaio
- Dec 27, 2020
Hi there,
Summary:
I had an issue with my pool being degraded after moving components to a new case & motherboard.
However, now the pool is back online and TrueNAS does not give me errors anymore during boot.
I'm running a long smart test on the incriminated drive, but I suspect the issue was due to the Sata cable not being fully plugged.
Extended version:
I am running TrueNAS on an old Core 2 Quad, with six WD Red drives formatted in Raid Z2 and two usb drives for boot.
It's important to state that all the drives are WDC WD40EFRX-68N32N0, but while 5 of them are only two years old, one of them is 5 years old.
Last week I proceeded to move the drives to a newer Intel i7 6700K, but after encountering a few problems with network and possibly CPU, I decided to move everything back to the old Core 2 Quad system.
As soon as I booted, TNAS started throwing several read errors while mounting the drives.
I got a notification email telling me which drive and surprisingly, it was one of the new ones, not the 4-5 years old one.
I rebooted another couple of times, same problem, so I turned off the computer and started procuring a replacement drive.
After a few days keeping the NAS off, I finally have the replacement drive, but out of curiosity I checked the sata cable on the existing drive and noticed that it wasn't 100% plugged, I would say 75% in.
I plugged the cable deeply, and did a first boot: no more console errors.
The pool still shows up as degraded with unrecoverable errors and a red tick.
I reboot again: now it shows up as online with the green tick.
So now I'm running a long smart test on the incriminated drive, just to see if it is really faulty.
Now, my questions:
Kind regards,
Stefano
Summary:
Extended version:
Now, my questions:
- Could a lightly attached Sata cable cause these kind of errors?
- Sorry for not posting the specific errors I received, I didn't take a screenshot of it when it happened.
- Curiosity: is there a way to find the error log so that I can pull up these errors?
- If the smart test doesn't return errors, I guess I should run a scrub on the pool?
- If the drive comes completely clean, should I replace it anyway?
- I cannot find any option to replace the disk, I followed this guide and these menus are just not there... I'm not going to how swap the disk, I will simply turn off the nas and swap the drive - will that make the option appear?
Kind regards,
Stefano
