godsfshrmn
- Jun 23, 2014
Received email alert about pool being degraded
Less than a minute later:
I log in to replace with a spare drive, but there are no alerts or a cleared alert that was from this email.
zpool status
Bingo correct? Resilvered a few sectors?
Last smartctl however does not seem to suggest a problem? Maybe I am not reading correctly?
Note Power on hours--- drives in this pool are now over 7 years old. Given the error and age, I'm going to replace the drive anyways. Thoughts on these reports?
Running a Long test currently. I think the RAW_READ_ERROR_RATE is way too high and that alone indicates need for replacement? Trying to learn a bit here and be proactive. Thanks
New alerts: * Pool freenas state is DEGRADED: One or more devices has been removed by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state. The following devices are not healthy: Disk ATA ST3000VN000-1H41 S300PN3J is REMOVED Current alerts: * Pool freenas state is DEGRADED: One or more devices has been removed by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state. The following devices are not healthy: Disk ATA ST3000VN000-1H41 S300PN3J is REMOVED
The following alert has been cleared: * Pool freenas state is DEGRADED: One or more devices has been removed by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state. The following devices are not healthy: Disk ATA ST3000VN000-1H41 S300PN3J is REMOVED
zpool status
pool: freenas
state: ONLINE
scan: resilvered 7.55M in 00:00:03 with 0 errors on Tue Feb 8 08:21:26 2022
NAME STATE READ WRITE CKSUM
freenas ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/1693403a-f961-11e3-892d-0cc47a052893 ONLINE 0 0 0
gptid/16e784cc-f961-11e3-892d-0cc47a052893 ONLINE 0 0 0
gptid/5e9e9f4d-6f1e-11e7-ba8c-0cc47a052893 ONLINE 0 0 0
gptid/1791d445-f961-11e3-892d-0cc47a052893 ONLINE 0 0 0
gptid/17ed23a4-f961-11e3-892d-0cc47a052893 ONLINE 0 0 0
gptid/18400dec-f961-11e3-892d-0cc47a052893 ONLINE 0 0 0
=== START OF INFORMATION SECTION === Model Family: Seagate NAS HDD Device Model: ST3000VN000-1H4167 Serial Number: S300PN3J LU WWN Device Id: 5 000c50 074af9fdd Firmware Version: SC44 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5900 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue Feb 8 09:09:53 2022 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 77746752 3 Spin_Up_Time 0x0003 092 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 151 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 084 060 030 Pre-fail Always - 9216369236 9 Power_On_Hours 0x0032 027 027 000 Old_age Always - 64696 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 151 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 099 000 Old_age Always - 8590065666 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 078 059 045 Old_age Always - 22 (Min/Max 20/27) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 86 193 Load_Cycle_Count 0x0032 093 093 000 Old_age Always - 14083 194 Temperature_Celsius 0x0022 022 041 000 Old_age Always - 22 (0 15 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 64695 - # 2 Extended offline Completed without error 00% 64287 - # 3 Extended offline Completed without error 00% 63951 - # 4 Short offline Completed without error 00% 63634 - # 5 Extended offline Completed without error 00% 63545 - # 6 Short offline Completed without error 00% 63468 -
