I got a set of 4 brand-new SSDs and created a pool. And it's immediately degraded. Every type of SMART test turns up green.
Here's my zpool status:
And smartctl of the offending drive:
It looks to me like the reserved space is a little bit too low. I'm not sure if this is a real actual problem, nor if it's correct for TrueNAS to "trip over" this pre-fault. Isn't reserved space supposed to vary from drive to drive anyway?
So the question is: is it safe to use this drive, and if so, how do I tell TrueNAS to go and use it as normal?
pool: SSD state: DEGRADED status: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Replace the faulted device, or use 'zpool clear' to mark the device repaired. config: NAME STATE READ WRITE CKSUM SSD DEGRADED 0 0 0 raidz1-0 DEGRADED 0 0 0 9636c9db-39f1-466b-b238-973bfee2a415 ONLINE 0 0 0 57ba6532-4e94-42c2-a513-14e6dc8127ab ONLINE 0 0 0 05df70c4-4f3f-4939-a597-f0a31d67a635 ONLINE 0 0 0 cdc73920-be07-4cc3-a996-0511ae1df527 FAULTED 0 28 0 too many errors errors: No known data errors
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.131+truenas] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: WD Blue / Red / Green SSDs Device Model: WDC WDS500G1R0A-68A4W0 Serial Number: 214703A00055 LU WWN Device Id: 5 001b44 8bc38af2b Firmware Version: 411000WR User Capacity: 500,107,862,016 bytes [500 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5 SATA Version is: SATA 3.3, 6.0 Gb/s (current: 1.5 Gb/s) Local Time is: Mon Sep 26 17:50:30 2022 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x02) Offline data collection activity was completed without error. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 10) minutes. SMART Attributes Data Structure revision number: 4 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0032 100 100 --- Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 --- Old_age Always - 10 12 Power_Cycle_Count 0x0032 100 100 --- Old_age Always - 8 165 Block_Erase_Count 0x0032 100 100 --- Old_age Always - 65536 166 Minimum_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 0 167 Max_Bad_Blocks_per_Die 0x0032 100 100 --- Old_age Always - 130 168 Maximum_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 0 169 Total_Bad_Blocks 0x0032 100 100 --- Old_age Always - 283 170 Grown_Bad_Blocks 0x0032 100 100 --- Old_age Always - 0 171 Program_Fail_Count 0x0032 100 100 --- Old_age Always - 0 172 Erase_Fail_Count 0x0032 100 100 --- Old_age Always - 0 173 Average_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 0 174 Unexpected_Power_Loss 0x0032 100 100 --- Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 --- Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 --- Old_age Always - 0 188 Command_Timeout 0x0032 100 100 --- Old_age Always - 0 194 Temperature_Celsius 0x0022 075 030 --- Old_age Always - 25 (Min/Max 21/30) 199 UDMA_CRC_Error_Count 0x0032 100 100 --- Old_age Always - 11 230 Media_Wearout_Indicator 0x0032 001 001 --- Old_age Always - 0x000000000000 232 Available_Reservd_Space 0x0033 100 100 004 Pre-fail Always - 100 233 NAND_GB_Written_TLC 0x0032 100 100 --- Old_age Always - 0 234 NAND_GB_Written_SLC 0x0032 100 100 --- Old_age Always - 3 241 Host_Writes_GiB 0x0030 253 253 --- Old_age Offline - 3 242 Host_Reads_GiB 0x0030 253 253 --- Old_age Offline - 6 244 Temp_Throttle_Status 0x0032 000 100 --- Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Conveyance offline Completed without error 00% 0 - # 2 Extended offline Completed without error 00% 9 - Selective Self-tests/Logging not supported
