System: Supermicro SYS-7048R-C1R4+
Motherboard: Supermicro X10DRC-LN4+
Processors: 2x Intel Xeon 2670v3
Memory: 128 GB ECC - DDR4 2133
OS: TrueNAS-13.0-U3.1
Mechanical: 8x Seagate Exos X16 12TB
NVMe: 4x MSI M470 2TB
SSD: 8x Kingston DC450R 1.92TB
HBA: LSI 9300-8i for SSDs
Motherboard SATA ports for mech
PCI-E x16 carrier for nvme drives.
Network: 4x Intel 82599 10GB SFP+ ports
Problem: The Kingston DC450R's are acting weird. Specifically da3. Moved drives on backplane, no change. Swapped drives, no change, da3 errors.
Error:
Error: [Errno 5] Input/output error
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p2 amd64] (local build)
Model Family: Phison Driven SSDs
Device Model: KINGSTON SEDC450R1920G
Serial Number: 50026B7282DA0F0D
LU WWN Device Id: 5 0026b7 282da0f0d
Firmware Version: SCEKH3.7
User Capacity: 1,920,383,410,176 bytes [1.92 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic, zeroed
ATA Version is: ACS-3 (minor revision not indicated)
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Dec 5 10:21:31 2022 PST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 30) seconds.
capabilities: (0x79) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
Conveyance self-test routine
recommended polling time: ( 3) minutes.
1 Raw_Read_Error_Rate 0x0032 100 100 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 3
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 11
167 Write_Protect_Mode 0x0000 100 100 000 Old_age Offline - 0
168 SATA_Phy_Error_Count 0x0012 100 100 000 Old_age Always - 19
169 Bad_Block_Rate 0x0000 100 100 000 Old_age Offline - 0
170 Bad_Blk_Ct_Erl/Lat 0x0000 100 100 010 Old_age Offline - 0/655
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
173 MaxAvgErase_Ct 0x0000 100 100 000 Old_age Offline - 1
181 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
182 Erase_Fail_Count 0x0000 100 100 000 Old_age Offline - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
192 Unsafe_Shutdown_Count 0x0012 100 100 000 Old_age Always - 8
193 Power_Fail_Uncompl_Cnt 0x0000 100 100 000 Old_age Offline - 0
194 Temperature_Celsius 0x0022 071 070 000 Old_age Always - 29 (Min/Max 22/30)
195 Power_Fail_Health 0x0000 100 100 000 Old_age Offline - 100
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
199 SATA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 17
207 Thermal_Throttling_Cnt 0x0000 100 100 000 Old_age Offline - 0
218 CRC_Error_Count 0x0032 100 100 000 Old_age Always - 17
231 SSD_Life_Left 0x0000 100 100 000 Old_age Offline - 100
232 Read_Fail_Count 0x0013 100 100 000 Pre-fail Always - 0
233 Flash_Writes_GiB 0x0032 100 100 000 Old_age Always - 0
241 Lifetime_Writes_GiB 0x0032 100 100 000 Old_age Always - 0
242 Lifetime_Reads_GiB 0x0032 100 100 000 Old_age Always - 0
244 Average_Erase_Count 0x0000 100 100 000 Old_age Offline - 0
245 Max_Erase_Count 0x0000 100 100 000 Old_age Offline - 1
246 Total_Erase_Count 0x0000 100 100 000 Old_age Offline - 384
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 3 -
# 2 Extended offline Completed without error 00% 2 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
I did however see smart errors showing from DA2 and DA3 complaining about attributes. But they don't show back up after clearing. But DA3 even after replacing it, refuses to wipe so I can't make a pool with it. I no longer get SMART errors however after I upgraded the BIOS and Firmware on the LSI card. I used the latest available. Firmware 17.0
We are attempting another backplane as well as another cable to the backplane.
