Aflac_Attack
- Apr 21, 2018
So I have a recently installed pretty vanilla build of Freenas 11.1u4 I'm trying to use as a file/media server in a Windows environment. It's a 3-drive Raid-Z (encrypted) that I set up with a couple user accounts/groups and SMB shares and that's it. I set up the Volume/Datasets and permissions and got it working as a networked drive. Transferred a couple Terabytes of stuff over to it while I was still in the testing phase and it seemed to be working perfectly for a couple days.
However, I discovered that whenever I try to do a scrub on the array it will eventually crash/hang/hard-lock. Seems completely random when it does it too. Could be going for 5 minutes or 3 hours but eventually the system becomes completely unresponsive. The connected display will either freeze on the Freenas main settings window (The 1-12 thing, don't know what it's called) or it will just go blank. I'll try to access the GUI but can't and I'll try to ping it to see that it's no longer on the network. I have a CMD prompt on my PC's second monitor pinging it constantly so I can monitor it and it will be going for a while until it starts getting the "Destination host unreachable" or "Request timed out". As soon as it loses the network connection seems to be the same time the system crashes. A power off/reset is the only way to get it back.
Tried all manner of BIOS tweaks. Turning all power saving stuff off, turning down RAM speeds, turning off ECC, disabling virtualization stuff, ect. There is no overclock running.
CPU temperatures and voltages are not a problem. SMART status is fine.
Don't know if it's related but the SMART process seems to be failing to initialize on the boot USB
Components:
Anyone have any ideas or experience with this problem? Any tips or suggestion on how I fix this? Thanks.
- "freenas smartd [2614]: Unable to register device /dev/da0 (no Directive -d removable). Exiting."
- "Error 22:rrdtool failed: ERROR: opening '/var/db/collectd/rrd/localhost//aggregation-cpu-sum/cpu-user.rrd': No such file or directory"
- " Error 201:[ENOMETHOD] Method "summary" not found in "network.general"
Components:
- Ryzen R5 1600
- Asrock x370 Taichi (Latest BIOS)
- 16 GB RAM (ECC) (2x 8 GB sticks) (KVR24E17S8/8)
- 3x WD 10 TB Red Pro
- 1x 500GB Samsung 850 Evo for VM's eventually (Currently not used)
- 1x 8 GB USB 3.0 drive for boot
- GTX 9800 GT (for display purposes)
- Seasonic Focus Plus 550W PSU (SSR-550FX)
- Cyberpower 1350 VA UPS (Never seen the load go over 120W)
