Hi.
Installing syncthing via gui in 11.2 RC1. Test server with new/clean install. Comes up and syncing to local devices seem to work but it cannot connect to any outside relays. Did some reading and tried and verified the following:
- The iocage has internet. Can ping and nslookup out by IP or DNS name.
- Installed self-signed certificate in Freenas based on this error I'm getting and research:
- Manually forwarded ports and tried applying uPNP directly to Iocage. Nothing.
Here is what the logs say:
Goes in a loop in the logs
Attempted this also on 11.1 BETA 5 and 6 and still no dice. I have a windows installation of Syncthing, unraid docker version, and a couple of android versions on the network and they can hit the outside relay.
Any ideas?
2018-10-25 00:39:46 Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
2018-10-25 00:39:46 Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
2018-10-25 00:39:46 c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (1.000000 failures of 2.000000), restarting: true, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
2018-10-25 00:39:47 Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
2018-10-25 00:39:47 c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (1.991662 failures of 2.000000), restarting: true, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
2018-10-25 00:39:47 Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
2018-10-25 00:39:47 Entering the backoff state.
2018-10-25 00:39:47 c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (2.973988 failures of 2.000000), restarting: false, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
Any ideas?
