Syncthing does not connect to relay
bmac6996
Hi.
Installing syncthing via gui in 11.2 RC1. Test server with new/clean install. Comes up and syncing to local devices seem to work but it cannot connect to any outside relays. Did some reading and tried and verified the following:
- The iocage has internet. Can ping and nslookup out by IP or DNS name.
- Installed self-signed certificate in Freenas based on this error I'm getting and research:
- Manually forwarded ports and tried applying uPNP directly to Iocage. Nothing.
Here is what the logs say:
2018-10-25 00:39:46 Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
2018-10-25 00:39:46 Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
2018-10-25 00:39:46 c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (1.000000 failures of 2.000000), restarting: true, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
2018-10-25 00:39:47 Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
2018-10-25 00:39:47 c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (1.991662 failures of 2.000000), restarting: true, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
2018-10-25 00:39:47 Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
2018-10-25 00:39:47 Entering the backoff state.
2018-10-25 00:39:47 c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (2.973988 failures of 2.000000), restarting: false, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
Goes in a loop in the logs
Attempted this also on 11.1 BETA 5 and 6 and still no dice. I have a windows installation of Syncthing, unraid docker version, and a couple of android versions on the network and they can hit the outside relay.
Any ideas?
D
dlavigne
Guest
Please create a report at bugs.freenas.org and post the issue number here.
ronclark
I have the same problem on both my Syncthing jails with Freenas 11.2, were you able to fix the problem?
joeyboon
I'm running in to the same problem and have been troubleshooting this for hours. Anyone has a solution?
ronclark
I posted a bug report here is the number Bug #77115
onyxfire
That bug has now been migrated to the new JIRA on bugs.ixsystems.com with the bug ID NAS-100968. With the new JIRA bug platform, you can create an account or login with your existing one and vote for issues. Everyone who is having this issue should vote to get that issue off the "backlog" so maybe they will realize it needs to be fixed.
ronclark
Thanks for the heads up, Ill put in my vote
ronclark
