RMA or not ? SSD had some read and write errors and 1 checksum error
hey,
i'm bad at cli smart information, so with the last update i shutdown truenas and looked at the disk with crystaldisk, which showed no smart errors. this was before the checksum error.
i replaced the cable to exclude that. and after some time i got the checksum error.
so maybe the read and write errors were because of a bad cable. i forgot how many errors it was, not many, maybe 4 write and 1 read +/- or 4 read 1 write
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.107+truenas] (local build)
Device Model: Patriot P220 1024GB
Serial Number: P220ADBB221103046
LU WWN Device Id: 5 000000 0000027b6
Firmware Version: H220829a
User Capacity: 1,024,209,543,168 bytes [1.02 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic, zeroed
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Sep 6 22:40:56 2023 CEST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 33) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 85) minutes.
Conveyance self-test routine
SCT capabilities: (0x0031) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 20
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
5 Reallocated_Sector_Ct ------+ 100 100 050 - 420
9 Power_On_Hours ------+ 100 100 000 - 4044
12 Power_Cycle_Count ------+ 100 100 000 - 25
167 Unknown_Attribute ------+ 100 100 000 - 0
168 Unknown_Attribute ------+ 100 100 000 - 2
169 Unknown_Attribute ------+ 100 100 010 - 1803893473388
173 Unknown_Attribute ------+ 200 200 000 - 34361442318
175 Program_Fail_Count_Chip ------+ 100 100 010 - 0
180 Unused_Rsvd_Blk_Cnt_Tot ------+ 094 094 000 - 386
192 Power-Off_Retract_Count ------+ 100 100 000 - 21
194 Temperature_Celsius ------+ 032 032 000 - 32 (Min/Max 23/46)
231 Unknown_SSD_Attribute ------+ 095 095 005 - 1280
233 Media_Wearout_Indicator ------+ 100 100 000 - 12569
234 Unknown_Attribute ------+ 100 100 005 - 3510711
241 Total_LBAs_Written ------+ 100 100 000 - 3128
242 Total_LBAs_Read ------+ 100 100 000 - 1071
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 51 Comprehensive SMART error log
0x03 GPL R/O 64 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (64 sectors)
Device Error Count: 2
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 2 [1] occurred at disk power-on lifetime: 3592 hours (149 days + 16 hours)
When the command that caused the error occurred, the device was in an unknown state.
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 41 00 50 00 00 2e 7d ac 38 40 00 Error: UNC at LBA = 0x2e7dac38 = 779988024
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 00 50 00 00 00 00 2e 7d ac 50 40 80 28d+01:39:36.200 READ FPDMA QUEUED
ea 00 00 00 00 00 00 00 00 00 00 00 80 28d+01:39:34.300 FLUSH CACHE EXT
ea 00 00 00 00 00 00 00 00 00 00 00 80 28d+01:39:34.200 FLUSH CACHE EXT
ea 00 00 00 00 00 00 00 00 00 00 00 80 28d+01:39:33.400 FLUSH CACHE EXT
Error 1 [0] occurred at disk power-on lifetime: 1192 hours (49 days + 16 hours)
40 -- 41 00 08 00 00 1f 5e df a8 40 00 Error:
00 00 00 00 00 00 00 1f 5e de 48 40 02 09:14:59.300 NOP [Abort queued commands]
ea 00 00 00 00 00 00 00 00 00 00 00 80 09:14:57.700 FLUSH CACHE EXT
ea 00 00 00 00 00 00 00 00 00 00 00 80 09:14:55.800 FLUSH CACHE EXT
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Extended offline Completed without error 00% 4026 -
# 2 Short offline Completed without error 00% 4003 -
# 3 Short offline Completed without error 00% 3980 -
# 4 Extended offline Completed without error 00% 3958 -
# 5 Short offline Completed without error 00% 3935 -
# 6 Short offline Completed without error 00% 3912 -
# 7 Short offline Completed without error 00% 3889 -
# 8 Extended offline Completed without error 00% 3867 -
# 9 Short offline Completed without error 00% 3844 -
#10 Short offline Completed without error 00% 3821 -
#11 Extended offline Completed without error 00% 3799 -
#12 Short offline Completed without error 00% 3776 -
#13 Short offline Completed without error 00% 3753 -
#14 Short offline Completed without error 00% 3731 -
#15 Extended offline Completed without error 00% 3708 -
#16 Short offline Completed without error 00% 3686 -
#17 Short offline Completed without error 00% 3662 -
#18 Extended offline Completed without error 00% 3640 -
#19 Short offline Completed without error 00% 3617 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
128 0 65535 Read_scanning was never started
SCT Status Version: 3
SCT Version (vendor specific): 1 (0x0001)
Device State: Active (0)
Current Temperature: 38 Celsius
Power Cycle Min/Max Temperature: ?/45 Celsius
Lifetime Min/Max Temperature: ?/ ? Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: -127/127 Celsius
Min/Max Temperature Limit: -127/127 Celsius
Temperature History Size (Index): 478 (34)
Index Estimated Time Temperature Celsius
35 2023-09-06 14:43 35 ****************
36 2023-09-06 14:44 36 *****************
37 2023-09-06 14:45 36 *****************
38 2023-09-06 14:46 37 ******************
39 2023-09-06 14:47 36 *****************
40 2023-09-06 14:48 35 ****************
41 2023-09-06 14:49 35 ****************
42 2023-09-06 14:50 36 *****************
43 2023-09-06 14:51 35 ****************
44 2023-09-06 14:52 36 *****************
... ..( 8 skipped). .. *****************
53 2023-09-06 15:01 36 *****************
54 2023-09-06 15:02 35 ****************
55 2023-09-06 15:03 36 *****************
64 2023-09-06 15:12 36 *****************
65 2023-09-06 15:13 37 ******************
66 2023-09-06 15:14 36 *****************
67 2023-09-06 15:15 35 ****************
68 2023-09-06 15:16 36 *****************
... ..( 4 skipped). .. *****************
73 2023-09-06 15:21 36 *****************
74 2023-09-06 15:22 31 ************
75 2023-09-06 15:23 35 ****************
76 2023-09-06 15:24 36 *****************
... ..( 6 skipped). .. *****************
83 2023-09-06 15:31 36 *****************
84 2023-09-06 15:32 37 ******************
85 2023-09-06 15:33 36 *****************
86 2023-09-06 15:34 36 *****************
87 2023-09-06 15:35 36 *****************
88 2023-09-06 15:36 37 ******************
89 2023-09-06 15:37 37 ******************
90 2023-09-06 15:38 36 *****************
91 2023-09-06 15:39 37 ******************
92 2023-09-06 15:40 36 *****************
93 2023-09-06 15:41 37 ******************
... ..( 3 skipped). .. ******************
97 2023-09-06 15:45 37 ******************
98 2023-09-06 15:46 39 ********************
99 2023-09-06 15:47 39 ********************
100 2023-09-06 15:48 40 *********************
... ..( 3 skipped). .. *********************
104 2023-09-06 15:52 40 *********************
105 2023-09-06 15:53 39 ********************
106 2023-09-06 15:54 39 ********************
107 2023-09-06 15:55 40 *********************
108 2023-09-06 15:56 38 *******************
109 2023-09-06 15:57 34 ***************
110 2023-09-06 15:58 36 *****************
111 2023-09-06 15:59 39 ********************
112 2023-09-06 16:00 38 *******************
113 2023-09-06 16:01 37 ******************
114 2023-09-06 16:02 39 ********************
115 2023-09-06 16:03 37 ******************
116 2023-09-06 16:04 38 *******************
117 2023-09-06 16:05 37 ******************
118 2023-09-06 16:06 38 *******************
119 2023-09-06 16:07 37 ******************
120 2023-09-06 16:08 37 ******************
121 2023-09-06 16:09 37 ******************
122 2023-09-06 16:10 38 *******************
123 2023-09-06 16:11 37 ******************
... ..( 2 skipped). .. ******************
126 2023-09-06 16:14 37 ******************
127 2023-09-06 16:15 38 *******************
... ..( 10 skipped). .. *******************
138 2023-09-06 16:26 38 *******************
139 2023-09-06 16:27 37 ******************
140 2023-09-06 16:28 37 ******************
141 2023-09-06 16:29 38 *******************
142 2023-09-06 16:30 38 *******************
143 2023-09-06 16:31 37 ******************
144 2023-09-06 16:32 38 *******************
145 2023-09-06 16:33 34 ***************
146 2023-09-06 16:34 32 *************
147 2023-09-06 16:35 36 *****************
148 2023-09-06 16:36 38 *******************
... ..( 20 skipped). .. *******************
169 2023-09-06 16:57 38 *******************
170 2023-09-06 16:58 39 ********************
171 2023-09-06 16:59 38 *******************
... ..( 5 skipped). .. *******************
177 2023-09-06 17:05 38 *******************
178 2023-09-06 17:06 37 ******************
179 2023-09-06 17:07 38 *******************
180 2023-09-06 17:08 37 ******************
181 2023-09-06 17:09 38 *******************
... ..( 21 skipped). .. *******************
203 2023-09-06 17:31 38 *******************
204 2023-09-06 17:32 37 ******************
205 2023-09-06 17:33 38 *******************
206 2023-09-06 17:34 38 *******************
207 2023-09-06 17:35 37 ******************
208 2023-09-06 17:36 38 *******************
212 2023-09-06 17:40 38 *******************
213 2023-09-06 17:41 39 ********************
214 2023-09-06 17:42 38 *******************
215 2023-09-06 17:43 38 *******************
216 2023-09-06 17:44 38 *******************
217 2023-09-06 17:45 39 ********************
218 2023-09-06 17:46 38 *******************
... ..( 4 skipped). .. *******************
223 2023-09-06 17:51 38 *******************
224 2023-09-06 17:52 39 ********************
225 2023-09-06 17:53 38 *******************
226 2023-09-06 17:54 39 ********************
227 2023-09-06 17:55 38 *******************
... ..( 14 skipped). .. *******************
242 2023-09-06 18:10 38 *******************
243 2023-09-06 18:11 39 ********************
... ..( 8 skipped). .. ********************
252 2023-09-06 18:20 39 ********************
253 2023-09-06 18:21 38 *******************
254 2023-09-06 18:22 39 ********************
... ..( 19 skipped). .. ********************
274 2023-09-06 18:42 39 ********************
275 2023-09-06 18:43 34 ***************
276 2023-09-06 18:44 34 ***************
277 2023-09-06 18:45 37 ******************
278 2023-09-06 18:46 38 *******************
279 2023-09-06 18:47 39 ********************
... ..( 2 skipped). .. ********************
282 2023-09-06 18:50 39 ********************
283 2023-09-06 18:51 40 *********************
284 2023-09-06 18:52 39 ********************
304 2023-09-06 19:12 39 ********************
305 2023-09-06 19:13 40 *********************
306 2023-09-06 19:14 39 ********************
307 2023-09-06 19:15 39 ********************
308 2023-09-06 19:16 37 ******************
309 2023-09-06 19:17 39 ********************
310 2023-09-06 19:18 40 *********************
311 2023-09-06 19:19 39 ********************
312 2023-09-06 19:20 39 ********************
313 2023-09-06 19:21 40 *********************
... ..( 2 skipped). .. *********************
316 2023-09-06 19:24 40 *********************
317 2023-09-06 19:25 39 ********************
318 2023-09-06 19:26 40 *********************
319 2023-09-06 19:27 41 **********************
320 2023-09-06 19:28 42 ***********************
... ..( 6 skipped). .. ***********************
327 2023-09-06 19:35 42 ***********************
328 2023-09-06 19:36 40 *********************
329 2023-09-06 19:37 40 *********************
330 2023-09-06 19:38 40 *********************
331 2023-09-06 19:39 41 **********************
332 2023-09-06 19:40 40 *********************
333 2023-09-06 19:41 40 *********************
334 2023-09-06 19:42 39 ********************
335 2023-09-06 19:43 40 *********************
336 2023-09-06 19:44 39 ********************
337 2023-09-06 19:45 40 *********************
338 2023-09-06 19:46 40 *********************
339 2023-09-06 19:47 39 ********************
340 2023-09-06 19:48 39 ********************
341 2023-09-06 19:49 39 ********************
342 2023-09-06 19:50 40 *********************
343 2023-09-06 19:51 39 ********************
346 2023-09-06 19:54 39 ********************
347 2023-09-06 19:55 40 *********************
348 2023-09-06 19:56 40 *********************
349 2023-09-06 19:57 39 ********************
350 2023-09-06 19:58 40 *********************
351 2023-09-06 19:59 39 ********************
352 2023-09-06 20:00 40 *********************
353 2023-09-06 20:01 39 ********************
354 2023-09-06 20:02 39 ********************
355 2023-09-06 20:03 40 *********************
356 2023-09-06 20:04 40 *********************
357 2023-09-06 20:05 39 ********************
358 2023-09-06 20:06 40 *********************
365 2023-09-06 20:13 40 *********************
366 2023-09-06 20:14 39 ********************
367 2023-09-06 20:15 40 *********************
... ..( 4 skipped). .. *********************
372 2023-09-06 20:20 40 *********************
373 2023-09-06 20:21 39 ********************
374 2023-09-06 20:22 40 *********************
375 2023-09-06 20:23 39 ********************
376 2023-09-06 20:24 40 *********************
379 2023-09-06 20:27 40 *********************
380 2023-09-06 20:28 39 ********************
383 2023-09-06 20:31 39 ********************
384 2023-09-06 20:32 40 *********************
385 2023-09-06 20:33 39 ********************
386 2023-09-06 20:34 39 ********************
387 2023-09-06 20:35 39 ********************
388 2023-09-06 20:36 40 *********************
389 2023-09-06 20:37 39 ********************
390 2023-09-06 20:38 39 ********************
391 2023-09-06 20:39 40 *********************
392 2023-09-06 20:40 39 ********************
393 2023-09-06 20:41 40 *********************
394 2023-09-06 20:42 40 *********************
395 2023-09-06 20:43 40 *********************
396 2023-09-06 20:44 39 ********************
397 2023-09-06 20:45 39 ********************
398 2023-09-06 20:46 40 *********************
399 2023-09-06 20:47 40 *********************
400 2023-09-06 20:48 39 ********************
403 2023-09-06 20:51 39 ********************
404 2023-09-06 20:52 40 *********************
405 2023-09-06 20:53 39 ********************
406 2023-09-06 20:54 39 ********************
407 2023-09-06 20:55 39 ********************
408 2023-09-06 20:56 40 *********************
409 2023-09-06 20:57 39 ********************
410 2023-09-06 20:58 40 *********************
411 2023-09-06 20:59 39 ********************
412 2023-09-06 21:00 40 *********************
413 2023-09-06 21:01 39 ********************
414 2023-09-06 21:02 37 ******************
415 2023-09-06 21:03 38 *******************
416 2023-09-06 21:04 39 ********************
... ..( 16 skipped). .. ********************
433 2023-09-06 21:21 39 ********************
434 2023-09-06 21:22 40 *********************
435 2023-09-06 21:23 39 ********************
440 2023-09-06 21:28 39 ********************
441 2023-09-06 21:29 38 *******************
442 2023-09-06 21:30 39 ********************
445 2023-09-06 21:33 39 ********************
446 2023-09-06 21:34 38 *******************
447 2023-09-06 21:35 36 *****************
448 2023-09-06 21:36 36 *****************
449 2023-09-06 21:37 37 ******************
450 2023-09-06 21:38 38 *******************
457 2023-09-06 21:45 38 *******************
458 2023-09-06 21:46 39 ********************
459 2023-09-06 21:47 38 *******************
470 2023-09-06 21:58 38 *******************
471 2023-09-06 21:59 39 ********************
472 2023-09-06 22:00 38 *******************
3 2023-09-06 22:09 38 *******************
4 2023-09-06 22:10 32 *************
5 2023-09-06 22:11 37 ******************
6 2023-09-06 22:12 38 *******************
7 2023-09-06 22:13 38 *******************
8 2023-09-06 22:14 38 *******************
9 2023-09-06 22:15 37 ******************
10 2023-09-06 22:16 38 *******************
21 2023-09-06 22:27 38 *******************
22 2023-09-06 22:28 40 *********************
23 2023-09-06 22:29 40 *********************
24 2023-09-06 22:30 38 *******************
... ..( 9 skipped). .. *******************
34 2023-09-06 22:40 38 *******************
SCT Error Recovery Control command not supported
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 25 --- Lifetime Power-On Resets
0x01 0x010 4 4044 --- Power-on Hours
0x01 0x018 6 6561183109 --- Logical Sectors Written
0x01 0x020 6 135231717 --- Number of Write Commands
0x01 0x028 6 2247024369 --- Logical Sectors Read
0x01 0x030 6 30694676 --- Number of Read Commands
0x01 0x038 6 3617606560544 --- Date and Time TimeStamp
0x07 ===== = = === == Solid State Device Statistics (rev 1) ==
0x07 0x008 1 1 N-- Percentage Used Endurance Indicator
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 2 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 4 0 Transition from drive PhyRdy to drive PhyNRdy
0x000a 4 4 Device-to-host register FISes sent due to a COMRESET
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0010 2 0 R_ERR response for host-to-device data FIS, non-CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x0013 2 0 R_ERR response for host-to-device non-data FIS, non-CRC
thanks for reading
joeschmuck
Old Man
Hey,
You are also bad about telling us more about the problem. I an assume things but that doesn't help if i give you the wrong information. With that said, please follow the forum rules and provide us some information about your system, and exactly the problem you are having.
I looked briefly at your SMART data and I need to look at it again, it is odd at first glance. But time for dinner first.
joeschmuck
Old Man
After examining the SMART data, all looks fine. There are a lot of strange values such as 420 relocated sectors, any maybe that is true but you only have just over 4000 hours, the media wearout indicator it great (100 is good), your total LBA's written is low. You have the reserved blocks at a 94 value vice 100 so some of the blocks were used, which would make the reallocated sectors valid.
Based on what I see, this drive is presently good. The odd values in some of the areas is not too surprising, and the fact that a SMART Long test passes is a good sign. I would keep an eye on it.
Out of curiosity, why did you provide only this SMART data? Why not any other drives you have? Did you get a message indicating this drive was having some issue? Is this a boot drive or part of your pool?
I didn't answer your question on if you should RMA the drive or not. If it were me, I'd RMA the drive. It should not have any reallocated sectors on a SSD this early in it's life. The value in ID5 and ID180 would be my justification and the power on hours. You have just under half a year of power on hours, and not much data recorded either (~1.6GB), unless you have had this drive for a very long time and the counters have rolled over. But if it's in warranty, I'm sure the counters didn't roll over. I'd say it's failing fast. Could be a bad memory chip, things are not always perfect. I'm guessing here but RMA the drive.
because it's the only drive with errors. truenas had alerts for the read, write and checksum errors. it's part of a 2 wide mirror.
ok thanks a lot for your reply!
the counters didn't roll over, it's a new drive, well not anymore since ~4000h ago.
