mloiterman
- Jan 30, 2013
I'm having similar issues and have been battling for MONTHS with no progress. So, so frustrating. Ready to take this server and chuck it. I've tried the LSI and IT firmware with no changes. I've tried the following LSI firmware versions from SuperMicro:
https://www.ixsystems.com/community/threads/failed-to-read-smart-attribute-data.72468/#post-502263
I believe the issue is rooted in something in 11.2 and the timeouts for the LSI driver, but I have no data and this is only speculation.
Here are the kind of errors I'm getting
- 3008_FW_PH16.00.01.00.zip (IT and IR - currently on IR and staying)
- 3008_FW_PH10.00.03.00.zip (IT)
- Original firmware, but cannot determine version, but I don't recall having issue at that time. This was pre 11.2 which I believe is the source of the error.
pid 2232 (syslog-ng), uid 0: exited on signal 6 (core dumped) (da6:mpr0:0:6:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00 length 0 SMID 449 Aborting command 0xfffffe0001077570 mpr0: Sending reset from mprsas_send_abort for target ID 6 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 52 b0 00 00 00 80 00 00 length 65536 SMID 978 terminated ioc 804b loginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 51 a8 00 00 00 80 00 00 length 65536 SMID 316 terminated ioc 804b loginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 52 b0 00 00 00 80 00 00 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 52 28 00 00 00 80 00 00 length 65536 SMID 729 terminated ioc 804b l(da6:mpr0:0:6:0): CAM status: CCB request completed with an error oginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 51 20 00 00 00 80 00 00 length 65536 SMID 930 terminated ioc 804b l(da6:mpr0:0:6:0): Retrying command oginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 51 a8 00 00 00 80 00 00 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 50 a0 00 00 00 80 00 00 length 65536 SMID 886 terminated ioc 804b l(da6:mpr0:0:6:0): CAM status: CCB request completed with an error oginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 50 18 00 00 00 80 00 00 length 65536 SMID 802 terminated ioc 804b l(da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 52 28 00 00 00 80 00 00 oginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 51 20 00 00 00 80 00 00 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4f 98 00 00 00 80 00 00 length 65536 SMID 558 terminated ioc 804b l(da6:mpr0:0:6:0): CAM status: CCB request completed with an error oginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4f 10 00 00 00 80 00 00 length 65536 SMID 588 terminated ioc 804b l(da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 50 a0 00 00 00 80 00 00 oginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 50 18 00 00 00 80 00 00 (pass6:mpr0:0:6:0): ATA COMMAND PASS THROUGH(16). CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 480 te(da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4f 98 00 00 00 80 00 00 rminated ioc 804b loginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4f 10 00 00 00 80 00 00 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4f 08 00 00 00 08 00 00 length 4096 SMID 778 terminated ioc 804b lo(da6:mpr0:0:6:0): CAM status: CCB request completed with an error ginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4e 08 00 00 01 00 00 00 length 131072 SMID 765 terminated ioc 804b (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4f 08 00 00 00 08 00 00 loginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4d 48 00 00 00 c0 00 00 length 98304 SMID 867 terminated ioc 804b l(da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4e 08 00 00 01 00 00 00 oginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4c 48 00 00 01 00 00 00 length 131072 SMID 905 terminated ioc 804b (da6:mpr0:0:6:0): CAM status: CCB request completed with an error loginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0: (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4b 48 00 00 01 00 00 00 length 131072 SMID 671 terminated ioc 804b 6:loginfo 31130000 scsi 0 state c xfer 0 0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4a 48 00 00 01 00 00 00 length 131072 SMID 596 terminated ioc 804b (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4d 48 00 00 00 c0 00 00 loginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4c 48 00 00 01 00 00 00 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 49 48 00 00 01 00 00 00 length 131072 SMID 731 terminated ioc 804b (da6:mpr0:0:6:0): CAM status: CCB request completed with an error loginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 48 48 00 00 01 00 00 00 length 131072 SMID 293 terminated ioc 804b (da6:loginfo 31130000 scsi 0 state c xfer 0 mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 47 48 00 00 01 00 00 00 length 131072 SMID 805 terminated ioc 804b (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4b 48 00 00 01 00 00 00 loginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 4a 48 00 00 01 00 00 00 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 46 48 00 00 01 00 00 00 length 131072 SMID 186 terminated ioc 804b (da6:mpr0:0:6:0): CAM status: CCB request completed with an error loginfo 31130000 scsi 0 state c xfer 0 (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 58 ac 00 70 00 00 00 f8 00 00 length 126976 SMID 983 terminated ioc 804b (da6:loginfo 31130000 scsi 0 state c xfer 0 mpr0: Unfreezing devq for target ID 6 mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 49 48 00 00 01 00 00 00 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 48 48 00 00 01 00 00 00 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 47 48 00 00 01 00 00 00 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 1c da 46 48 00 00 01 00 00 00 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 58 ac 00 70 00 00 00 f8 00 00 (da6:mpr0:0:6:0): CAM status: CCB request completed with an error (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00 (da6:mpr0:0:6:0): CAM status: Command timeout (da6:mpr0:0:6:0): Retrying command (da6:mpr0:0:6:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00 (da6:mpr0:0:6:0): CAM status: SCSI Status Error (da6:mpr0:0:6:0): SCSI status: Check Condition (da6:mpr0:0:6:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) (da6:mpr0:0:6:0): Error 6, Retries exhausted (da6:mpr0:0:6:0): Invalidating pack
(da1:mpr0:0:1:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00 length 0 SMID 422 Aborting command 0xfffffe0001074ea0
mpr0: Sending reset from mprsas_send_abort for target ID 1
(da1:mpr0:0:1:0): READ(10). CDB: 28 00 57 e3 25 10 00 00 08 00 length 4096 SMID 435 terminated ioc 804b loginfo 31130000 scsi 0 state c xfer 0
(pass1:mpr0:0:1:0): ATA COMMAND PASS THROUGH(16). CDB: 85 08 0e 00 d5 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 640 terminated ioc 804b loginfo 31130000 scsi 0 state c xfer 0
(da1:mpr0:0:1:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00 length 0 SMID 220 terminated ioc 804b loginfo 311(da1:mpr0:0:1:0): CAM status: CCB request completed with an error
(da1:mpr0:0:1:0): Retrying command
(da1:mpr0:0:1:0): WRITE(16). CDB: 8a 00 00 00 00 01 04 bb 5c a8 00 00 00 08 00 00 length 4096 SMID 139 terminated ioc 804b lo(da1:mpr0:0:1:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00
mpr0: Unfreezing devq for target ID 1
(da1:mpr0:0:1:0): CAM status: Command timeout
(da1:mpr0:0:1:0): CAM status: SCSI Status Error
(da1:mpr0:0:1:0): SCSI status: Check Condition
(da1:mpr0:0:1:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred)
(da1:mpr0:0:1:0): Error 6, Retries exhausted
(da1:mpr0:0:1:0): Invalidating pack
- motherboard make and model
- SuperMicro X11SSH-CTF
- Firmware Revision : 01.48
- Firmware Build Time : 06/22/2018
- BIOS Version: 2.2
- BIOS Build Time: 05/23/2018
- Redfish Version : 1.0.1
- CPU make and model
- CPU: Intel(R) Xeon(R) CPU E3-1275 v5 @ 3.60GHz (3600.18-MHz K8-class CPU)
- Origin="GenuineIntel" Id=0x506e3 Family=0x6 Model=0x5e Stepping=3
- RAM quantity
- 32 GiB
- Crucial 2-16GB DDR4-2400 EUDIMM 1.2V CL17
- 32 GiB
- boot drive
- Intel SSD 600p Series SSDPEKKW128G7X1 (128 GB, M.2 80mm PCIe NVMe 3.0 x4, 3D1, TLC)
- hard drives, quantity, model numbers, and RAID configuration
- 8 x ST4000LM024
- RAIDZ2
- hard disk controllers
- Avago Technologies (LSI) SAS3008
- Code:
sas3flash -c 0 -list Avago Technologies SAS3 Flash Utility Version 16.00.00.00 (2017.05.02) Copyright 2008-2017 Avago Technologies. All rights reserved. Adapter Selected is a Avago SAS: SAS3008(C0) Controller Number : 0 Controller : SAS3008(C0) PCI Address : 00:01:00:00 SAS Address : 5003048-0-1e04-6000 NVDATA Version (Default) : 0e.01.31.27 NVDATA Version (Persistent) : 0e.01.31.27 Firmware Product ID : 0x2721 (IR) Firmware Version : 16.00.01.00 NVDATA Vendor : LSI NVDATA Product ID : LSI3008-IR BIOS Version : 08.37.00.00 UEFI BSD Version : 18.00.00.00 FCODE Version : N/A Board Name : LSI3008-IR Board Assembly : N/A Board Tracer Number : N/A Finished Processing Commands Successfully. Exiting SAS3Flash.
- network cards
- ix0: <Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.2.12-k> mem 0xd0200000-0xd03fffff,0xd0404000-0xd0407fff irq 16 at device 0.0 on pci4
- ix1: <Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.2.12-k> mem 0xd0000000-0xd01fffff,0xd0400000-0xd0403fff irq 17 at device 0.1 on pci4
- FreeNAS-11.2-U4 (Build Date: May 7, 2019 0:46)
