- Aug 16, 2011
So I'm considering upgrading my NAS to a newer motherboard. The Supermicro X9DRD-7LN4F-JBOD has worked well for the 7+ years I've had it, and I'm really not close to maxing it out, but the IPMI with its Java-based virtual console is a definite pain point, so I'm looking for somthing a bit newer. Hoping to get some suggestions for a replacement. Some needs/wants:
- I'm pretty sure I'd want to keep no less than the current 128 GB of RAM, but I doubt I'll need more than that
- Must have HTML5-based virtual console--no Java
- I rarely use a significant amount of CPU, so dual-socket isn't really needed
- I don't have strong feelings on Intel vs. AMD, though all my current gear is Intel FWIW
- The current board has an onboard LSI SAS HBA; I'm assuming I'll need that as an add-on card for the new board--I'm not expecting to find a new board with this integrated
- I'm assuming IPMI includes onboard (if limited) video; I don't intend to use a GPU with this
- I'm expecting to continue to use the Chelsio NIC, so onboard 10GbE isn't needed or particularly desirable
- I'm fine with my current Supermicro 847 36-bay chassis, but might consider converting it to a JBOD
- I'm not particularly interested in m.2 slots; my system boots from a SATA SSD
- Good availability on the secondary market is a plus--I'm probably favoring used gear here
- And, of course, budget is always a factor
