I've been thinking I want to get in to all of the ZFS goodness. I currently have a Synology DS1813 which has served me well but is linux mdadm RAID6, so not ZFS. :) That is running 8 x 4TB HGST NAS drives.
As it's getting to be 4 years old, I've been looking to upgrade it.
So, here is my current idea for a build. Comments welcome:
Case: Node 804 (already purchased), room for 10 HDD and 2 SSD
Motherboard: Supermicro X11SSL-CF (https://www.newegg.com/Product/Product.aspx?Item=2W2-0014-00023)
CPU: Intel Xeon E3-1230 V6 (https://www.newegg.com/Product/Product.aspx?Item=N82E16819117788)
CPU cooler: Noctua NH-U12S (https://www.newegg.com/Product/Product.aspx?Item=N82E16835608040)
RAM: 32 GB, 2x of Supermicro MEM-DR416L-SL01-EU24 (https://www.newegg.com/Product/Product.aspx?Item=9SIA7S67Y99082)
OS drives: 2x in mirror vdev, SAMSUNG 860 Pro (https://www.newegg.com/Product/Product.aspx?Item=N82E16820147684)
Storage drives: 10x in RAIDZ2, 6TB HGST Deskstar NAS (https://www.newegg.com/Product/Product.aspx?Item=N82E16822146118)
Power supply: Seasonic PRIME Snow Silent 750W (https://www.newegg.com/Product/Product.aspx?Item=N82E16817151221)
Case fans: case comes with 3, maybe will replace if too noisy
For the case fans, the Node 804 already has some included, so I am not sure if I need any at the moment. If I decide I do I would be going with Noctua something or other.
One of the goals of every computer I have is as much as possible it should be silent. So always 120mm+ fans everywhere, including the CPU cooler, on low speed settings, assuming no heat issues. Of course speed is adjusted as necessary.
The power supply I believe should be adequate based on power calculations as described here: https://forums.freenas.org/index.php?threads/proper-power-supply-sizing-guidance.38811/
A lot of these numbers are just guesses based on that article and some other internet lookups, but probably could be more accurate with more research time:
Max load:
Motherboard: 25w
Onboard LSI: 10w
CPU: TDP 72w
CPU fan: 15w ???
Case fans: 45w (3x15w) ???
RAM: 12w (2x6w)
HDD: 350w (10x35w)
Total: 529w
Idle load:
Motherboard: 25w
Onboard LSI: 10w
CPU: ??? using 30w for calculation
CPU fan: 15w ???
RAM: 12w (2x6w)
HDD: 73w (10x7.3w) per data sheet (https://www.hgst.com/sites/default/files/resources/DS_NAS_spec.pdf)
Total: 210w
The idle draw seems a bit high but maybe not for 10 drives. I didn't include anything for SSD's, but online articles seem to show around 1-2w, so I didn't really bother including it.
Anyways comments welcome on my build and also my power math.
Max load:
Motherboard: 25w
Onboard LSI: 10w
CPU: TDP 72w
CPU fan: 15w ???
RAM: 12w (2x6w)
HDD: 350w (10x35w)
Total: 529w
Idle load:
Motherboard: 25w
Onboard LSI: 10w
CPU fan: 15w ???
RAM: 12w (2x6w)
Total: 210w
