I didn't upgrade my pools, only the applications somehow updated themselves and now I can't go back@sstruke as part of you upgrade to cobia did you upgrade your pools? If so, due to the new OpenZFS feature flags changes the pools will not be compatible with Bluefin.
I don't believe they provide a way to return the Apps dataset to the previous version.I chose previous boot environment but it refuses to recognize the pole on which the applications are installed.
it returns me an
error: [EINVAL] kubernetes_update.force: Apps have been partially initialized on 'AppsVolume' pool but it is missing 'AppsVolume/ix-applications/docker' datasets. Specify force to override this and let system re-initialize applications.
On cobia apps work
However, it takes quite some time to delete and set up anew. That's why I'm looking for help so that I don't regret it laterI don't believe they provide a way to return the Apps dataset to the previous version.
This is the first beta of Cobia and intended for testing purposes only. It's not ready for valuable data you can't afford to lose and iXSystems have been pretty clear on that.
Restore to a backup or perhaps try wiping your Apps dataset and start over.
I don't know of a way but perhaps someone else here does, good luck.However, it takes quite some time to delete and set up anew. That's why I'm looking for help so that I don't regret it later
Thanks anywayI don't know of a way but perhaps someone else here does, good luck.
In fact, kobia doesn't even give me any problems, it has only one drawback that OneDrive sync is missingI don't know of a way but perhaps someone else here does, good luck.
OneDrive had to be removed because driver was not supported with current python.In fact, kobia doesn't even give me any problems, it has only one drawback that OneDrive sync is missing
Thanks for the infoOneDrive had to be removed because driver was not supported with current python.
NAS-121621 / 23.10 / remove onedrivesdk (deprecated a long time ago) by yocalebo · Pull Request #11143 · truenas/middleware
This module hasn't seen a commit since 2016 so it's dead and it does not work with python3.11 (ships in Cobia). There doesn't seem to be a decent alternative either so we'll drop this for now and r...github.com
go to the selected pool for apps, then ix-applications i.e. /mnt/'NAME_OF_POOL'/ix-applications, and delete apps_migrations.json and migrations.json. After reboot truenas and pray that none of your apps have changed.I chose previous boot environment but it refuses to recognize the pole on which the applications are installed.
it returns me an
On cobia apps work
