reloaded
- Nov 6, 2016
Hi, I have been called back to sort out a FreeNAS Mini system I set up, the O/S seems to be absent or trashed I have only had a little look-see. My guess is that I will have to completely re-install FreeNAS, I now know the "config" should have been backed up but I should be able to import the volumes. My question is, since I doubt that it was upgraded from 9.3 to 9.10, will there be any compatibility issues if I load 9.10 as the operating system with volumes which previously ran under 9.3? I presume I could download the 9.3 version and load that if needed.
