Replacing system dataset disk
Korril
I have my system dataset on a single SSD which I would like to replace. Could someone please outline the procedure to do this?
My NAS is set up to have a Storage dataset, and System dataset. Would using the Storage dataset automatically copy over the existing data in the System dataset? If so, could I switch to using the Storage Dataset, replace the SSD, and then reselect the SSD (new) pool as the System dataset pool?
Thanks in advance.
You're mixing dataset and pool in your description, but indeed, you can move the system dataset to your data pool (or the boot pool if your boot pool is on an SSD) and then back again after you do whatever work you need to do.
Davvo
What happens if you lose the dataset drive?
Since a lot of your system logging is redirected there, you can sometimes find system freeze or even panic/reboot.
If the data is lost, you won't see historical data in reports, system logs, etc, but the relevant files and structures are automatically re-created on reboot if they are missing.
Korril
Thanks for the replies. Apologgies if I get the terminology wrong.
Just to confirrm, if I select another pool to act as the System Dataset Pool, does all the current System dataset data get copied to the new System Dataset location?
Yes.
