Electr0
- Dec 18, 2020
Hi All,
I currently have two 250GB SSDs (ada0, ada1) installed in my server. Each with three partitions:
I want to replace both drives with 500GB SSDs.
What is the best way to go about this?
Is there a way in which I can Resilver the entire drive (all partitions) at once? Or will I have to Resilver each Boot and System Dataset partition individually?
If the latter, how do I do that? Do I need to create each (empty) partition individually first, then resilver the partitions?
Furthermore, what do I do about the EFI (adaXp1) partition? Do I need to also copy/mirror that somehow?
Thanks in advance.
- ada0p1 (260M) - EFI
- ada0p2 (29G) - Boot Pool
- ada0p3 (203G) - System Dataset Pool
- ada1p1 (260M) - EFI
- ada1p2 (29G) - Boot Pool
- ada1p3 (203G) - System Dataset Pool
Thanks in advance.
