Hello all,
I am planning to build a NAS based on Freenas. I took some hours to read about the hardware recommendations for Freenas. However, I decided to kindly ask for some specific advices here because it is hard to get a good overview of all that hardware available.
I first thought about a 4 bay NAS but because of the HDD prices I now think that a two bay with two larger HDDs will be just fine.
I don't think that I need ECC RAM. In case something goes wrong it is okay for me to restore some backups. I think I want to use at least 12 GB of RAM (since 8 GB is the absolute minimum recommendation).
Do you recommend a redundant boot disk? Or can I just do a fresh install of Freenas to a new device in case of a failure? And will I be able to access the data on the drives again with that fresh installation?
I want the NAS to have at least two NICs.
The NAS will only be used by me and at home. I plan to store about 4 TB of data on the device.
I hope you can give me some specific suggestions about mainboards, CPU etc.
