theomolenaar
- Jun 12, 2016
I'm in the process of building my own NAS. My current NAS is a Synology Diskstation DS414. At first the DS414 was ok. It's energy efficient, low maintenance and easy to install software packages. The biggest disadvantages for me is that it's unable to transcode when using Plex Media Server and that it's a 4-bay disk station. Hitting the maximum storage limit is just a matter of time. So I did some research and found out that FreeNAS could be my software solution for a dedicated home build NAS. For the hardware part I could use some help. Any tips, suggestions and recommendations on this build are very welcome. Thanks in advance.
I did a fair amount of research on every component. This is my current build:
The above build has a compatibility issue which I'm ignoring at the moment. It needs 3 additional SATA 6 Gb/s compatible ports. The Asus P9D motherboard has 6 SATA 6GB. So I will need an extra SATA PCI card with at least 3 SATA ports. And if I want to install 2 more HDD's in the 5,25" cages I need 2 more SATA ports.
Any recommendations on a 5+ port SATA PCI card?
REQUIREMENTS
Expandability (in storage)
I want to be able to add HDD's when necessary. So I will start with my 4 HDD's from my Diskstation. The Define R5 case supports up to 8 HDD's. If I need more space I could use the 5,25" cages and install 2 more HDD's. 10 HDD's is more than enough for me.
Silent
This server will be used as a home server, therefore, installed in the meter cupboard. This meter cupboard is in the hallway. Because it will run 24/7 and my bedroom and office are at the other end. The less noise the better. The possibility of optimizing fan speeds would be a great benefit.
As for the case I decided to go with the Define R5 because it’s designed to be ‘silent’. Other silent cases I found: Antec P100, Nanoxia Deep Silence 5, Corsair 550D and the NZXT H440.
Energy efficiency
This new server will run 24/7. Transcoding will be done a few hours a day when using Plex. The rest of the day/night some (lightweight) software packages and scripts will be running in the background. No gaming or overclocking.
Are there any components in this buid that could be switched for a more energy efficient one? Is the 550W PSU overkill and should I opt for a lower powered?
Plex transcoding and ECC support (for motherboard & CPU)
I want to be able to transcode up to 4 streams in 1080p. For a single 1080p stream Plex advices to have a PassMark score 0f 2000. The Xeon cpu has a PassMark of 9609. So that will be more than enough.
I decided to build a NAS that supports ECC. After some research I found out that not all Intel CPU's support ECC. See this list for ECC support. Most XEON cpu's have ECC support.
> Any recommendations for a cheaper CPU with a Passmark of at least 8000 and support for ECC?
> I3's, i5's and i7's have some ECC support but a lower PassMark score. Is there any Intel i3, i5 or i7 that supports ECC and has a 8000+ PassMark score that I'm not aware of?
Operating System
FreeNAS is my first choice for the operating system. But I want to be able to run other OS’es too. Ubuntu Server or Desktop also caught my attention. For hardware requirements see here. FreeNAS doesn’t mention any GPU as a requirement, but Ubuntu Server and Desktop do. Which brings me to the next requirement.
Headless server
The server will be installed in the meter cupboard and managed from another computer in the network. This suggest that I don’t need any videocard. However, if I want to run an OS with a GUI then I do need a video card or onboard GPU.
> Am I right that the currently selected hardware doesn’t have any GPU?
> Which GPU do you recommend for my use case? I don’t want another spinning fan inside my ‘silent’ case. Onboard GPU or a separate GPU card? Therefore, do I need another motherboard? Any recommendations?
Thanks again. Looking forward to seeing your recommendations and feedback. :)
- CPU Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor
- Motherboard Asus P9D WS ATX LGA1150 Motherboard
- Memory (RAM) Crucial 16GB (2 x 8GB) DDR3-1600 (ECC Unbuffered - CT2KIT102472BD160B)
- Boot Drive Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (MZ-75E250B/AM)
- Storage (8x) Western Digital Red 4TB 3.5" 5400RPM Internal Hard Drive (WD40EFRX)
- Case Fractal Design Define R5 (Black) ATX Mid Tower Case
- PSU Corsair RM 550W 80+ Gold Certified Fully-Modular ATX Power Supply
REQUIREMENTS
Silent
Energy efficiency
Operating System
Headless server
