I've been lurking for a while, and I think I've learned quite a bit about what hardware to use, but I've never worked with server equipment and I'm wary to go on assumptions.
First, I'll mention the use case so that I can properly frame my decisions. My nephew and I want to build twin systems and backup to each other's machines. So this will be a build with lots of drives compared to what would normally be needed in a home system. Mine at least, will also serve as a media server to stream to one or two devices at a time.
My plan:
FreeNAS version: not sure yet (see MB below)
Motherboard: Supermicro X10SLL-F-O (although this is a board cyberjock specifically recommends, Supermicro does not list any version of FreeNAS as a compatible OS)
CPU: Xeon E3 1220 v3
Memory: 2x Samsung 8 GB DDR3 1600 ECC (listed as tested memory for MB)
Boot disk: 16GB USB thumb drive (currently looking at Sandisk)
HBA: M1015
Backplane: SAS-826EL1
Drives:
Pool 1: 4x 2 TB drives in RAIDZ2(I read an article comparing Seagate NAS drives to WD Red and I'm leaning toward Seagate, but am definitely swayable on this point)
Pool 2: Match my nephew's Pool 1 as this will be his off-site backup
Pool 3: 1x 6 TB WD Blue to use as storage for Plex (~200 DVD's, ~50 Blu-Rays, and room to grow)
You may have noticed that I didn't include a chassis or power supply. These are where I have some questions.
Chassis:
I would like to build a custom case out of wood, mostly because I haven't liked the availability of inexpensive cases with hot-swappable drives. My first question is how important would hot-swappable drives be in this build. If not important, I could put this in any case with the requisite space, but then I would also need to rethink my controller / HBA situation. If it is important, how difficult might it be to use trays that ship with the Supermicro chassis' that use the backplane I've listed? Should I instead use the preconfigured bays (let's say two 4-drive bays, and one 1-drive bay), and if so, would I then need another HBA?
PSU:
Part of what originally made me consider building a box, was the lack of redundant power in cheap chassis'. How important is redundant power in this build? If I read cyberjock's and jgreco's various discussions properly, I should have quite a bit of power available for these 9 drives. So I'm thinking 800+, but the redundant PSU's of this capacity seem to be quite expensive (like a third of the rest of the build cost including drives, or nearly the same as the rest of the parts). How crucial is redundancy? In cyberjock's recommended build guide, it is recommended to not skimp on the PSU, but I see no mention as to whether this means get a redundant solution. Also note, I will be getting a UPS, but I know that this has nothing to do with redundancy. Should a high quality ATX PSU work for 5 years? If it does fail, how likely is it that my pools are garbage?
Lastly, I feel like the CPU and MB are overkill, but I had a hard time finding recommended hardware that would support the number of drives I need, as many of the boards only have one expansion slot and provide no room for needing another HBA (if I do happen to need another). Am I correct? Am I working under improper understanding of the drive control?
A note about budget:
I would probably spend up to ~$2500 US if necessary as I really want to do it, but my nephew is comparing this to cloud storage solutions, so probably more realistically around $1500 would be the max assuming a 5 year life.
Thanks,
oran0007
My plan:
HBA: M1015
Drives:
Chassis:
PSU:
Thanks,
oran0007
