I am going to be building a large storage array for the compay and I wanted to get some advice from you guys as I will be using FreeNAS to power the build.
The main requirement for me is throughput of the data, both with reads and write, and making sure that it is rock solid build and fully redundant.
I am considering two systems with identical specs. The specs I'll be listing are per server. I plan on using ZFS zend/receive to keep these machines in sync.
The platform I've picked is the supermicro chassis. Here is a link to it: https://www.supermicro.com/products/system/4U/6048/SSG-6048R-E1CR60L.cfm
Specs of what will be in each server:
Memory: 256GB Memory of DDR4 2400MHz ECC Reg
CPU: INTEL XEON 6 CORES 1.7Ghz 15M
Storage Drives: 30x6TB Drives (every 2x6TB Drives will be paired for raid 1, each pair will create the overall storage array)
ZIL Drives: 2x1TB MLC SSD Drives (Mirrored)
L2ARC Drives: 2x1TB MLC SSD Drives
HDD Connectivity: 2 HBA LSI 3008 in IT mode (JBOD)
Networking: 1 NIC w/2x10GB Ports.
Is there anything I might be missing? Anything I should be concerned about or what about anything that you guys might change for the build?
Thanks in Advance!
Thanks in Advance!
