Miroslav Mandrino
 - Nov 7, 2016
Hi Guys,
I had a FreeNAS running with 6x2TB wd HDDs. Had a Z2 pool on them. All worked well, and I had a usb copy made(mirrord a boot device - maybe the wrong way). When the usb went wrong, I reinstalled a fresh copy on new usb (bkp also didn't boot) and restored the pool. I used zpool import -f ID command, and I could access data.
Then I decided to move hdds to new MB into a new chassis. Installed freenas FreeNAS-9.10.1-U2 and I was happy to see my pool and tried to import it the same way. Import from gui shows no volumes, Import from shell was successful, but volume doesn't show in GUI. Also after import when i user zfs mount it mouts the volume to /Volume... but maybe I got parameters wrong.
Then I wanted to wipe disks and start new. It was just a test storage.
Creating volume gives me an error Error: Unable to GPT format the disk "ada0"
I cannot do wipe - Error: Failed to wipe ada0p2: dd: /dev/ada0p2: Operation not permitted
I tried
sysctl kern.geom.debugflags=0x10
dd if=/dev/zero of=/dev/ada0 bs=512 count=1 from forum, no error, no result - still can't wipe or create new volume.
So now I am stuck. I went through manual, FAQ, and searched the forum, but no luck. No answers solves or explains my situation :(
From /var/log/messages : freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord
but this is not a critical error as I understand.
Thank you very much
I tried
Thank you very much
