Problem with USB ?!
Jano
I have installed FreeNas 9.10 U4... I have problems with USB ports:
PROD-2S.igexao.local kernel log messages:
> ugen1.3: <Prolific Technology Inc.> at usbus1 (disconnected)
> uplcom0: at uhub4, port 1, addr 3 (disconnected)
> usb_alloc_device: set address 3 failed (USB_ERR_STALLED, ignored)
> usbd_setup_device_desc: getting device descriptor at addr 3 failed, USB_ERR_STALLED
> usbd_req_re_enumerate: addr=3, set address failed! (USB_ERR_STALLED, ignored)
> ugen1.3: <Unknown> at usbus1 (disconnected)
> uhub_reattach_port: could not allocate new device
> uplcom0: <Prolific Technology Inc. USB-Serial Controller D, class 0/0, rev 1.10/4.00, addr 3> on usbus1
> usb_alloc_device: set address 3 failed (USB_ERR_TIMEOUT, ignored)
-- End of security output --
What is interesting I have such behaviour on 2 computers which previously worked fine with FreeNas 9.3 (nothing changed in hardware configuration, just FN update)
Problem listed above occure after some time of working.... few hours all is fine and then boom.
In fact I have 2 UPS connected via USB cables and at the begining I thought there is problem with NUT which reguraly, after some time of correct working, just loses connection with UPS.
Any ideas ?
joeschmuck
Old Man
Since this started happening when you installed U4, I'd recommend rolling back to your previous version and ensure the problem does not come back. If that is the case, write up a bug report.
I'm running U2 on my main system just because I have seen too many problems listed on the forums.
Just updated my backup to -U4. I doubt USB is acting up, since it boots from USB flash drives.
Jano
My system is also booted from USB drive and all is working fine... or maybe I do not see problems.
Only problems (described above) I have with connected UPS (One connected directly, second via USB->RC232 converter).
Like joesmuck propose I'm going to prepare new drive with FN9.3 and check if problem also exists now.
Jano
Ok, system reinstalled to FY9.3 (last update) and is working correctly for alsmost 3 days (while previous FY9.10 failed after few hours).
Going to declare bug for this issue.
SweetAndLow
Sweet'NASty
This thread is worthless without hardware specs.
