Plugins and file ownership, what is the best way to correctly force nobody/nobody?
dabone
I've got my box setup with open shares for smb, my problem is that when I'm using plugins, the direct access to the mount points are allowing screwed up ownership/groups.
It there a way to mount the smb shares under the jail?
Or how about a cron job every few hours to reset grp/owner? (chown -R nobody /mnt/*) ??
Plugins that I'm using are sickbeard, sabnzbd, transmission, and couch potato.
Thanks.
(Edited due to stupidity showing... chmod instead of chown.)
Top Bottom
