Imoldgregg
- Nov 21, 2019
Hi all,
I have searched through this forum but cannot seem to find an answer to my issue. I am following this guide
www.ixsystems.com
To install plex manually into a Jail, however when I start the service, which starts sucesfully, and go to the webpage I get "page cannot be displayed".
Here are my specs:
Freenas Version : FreeNAS-11.2-U7
Physical Memory: 16209 MiB
Model: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
I have manually configured the IP on the jail install, and from the shell in the jail I can see the IP configered correctly:
and my netstat output
I can ping externally and addreses on my local network from within the jail shell. Service is running =
Jail settings:
Is there anything I am missing? Any help would be appreciated! Thanks.
Al
(Tutorial) How To Install Plex in a FreeNAS 11.2 Jail
How To Install Plex in a FreeNAS 11.2 Jail: Follow the instructions on how to create a jail, and set the following: Jail Name: plex Release: pick the latest VNET: checked IPv4 Interface: vnet0 IPv4 Address: select something that is on your network and outside of your DHCP scope (e.g...
Here are my specs:
Jail settings:
Al
