Plex and Jellyfin apps won't start
jmcguire525
Cleanest way is to always plan the use of /mnt/pool/dataset as base, for example /mnt/default/media. Inside it, you can create or move all the directories you want and never worry about any issues in Plex or any other application. This is actually the intended use of a shared dataset.
While there, don't forget to add a ramdisk, if you transcode in Plex. See discussion:
Is there any issue mounting the ramdisk to an existing directory since /tmp is created during installation?
kjs
Same problem here with Plex from Official Catalog (stuck DEPLOYING) when /data is in SMB type.
I use it in a Test environment with non-critical data and I use CLI to change:
app kubernetes update validate_host_path=false
after then Plex starts without problems
