pkg.FreeBSD.org could not be reached via DNS
urobe
Hey there, I'm trying to install emby on a freshly updated 11.03 U2 (initally it was a 11.03 install) and I get the following error:
 emjail had a failure Exception: RuntimeError Message: pkg.FreeBSD.org could not be reached via DNS, check emjail's network configuration Partial plugin destroyed
is this rahter a vnet problem or with the network setup? The device works otherwise fine (I haven't installed any other plugins). System updates are automatically found, downloaded and installed. So I guess, the BAsic network setup should be correct?
I read somewhere that the initial 11.03 Release had some vnet issues, but I thought they were figured out in U1.
Any advice is greatly appreciated.
Kind regards,
Tobi
What is your ifconfig in the jail?
urobe
Not sure, is this what you mean:
root@nas[~]# ifconfig
em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: em0
        options=209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
        ether 0c:c4:7a:4d:0a:63
        hwaddr 0c:c4:7a:4d:0a:63
        media: Ethernet autoselect
        status: no carrier
cxl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=e802bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO6,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        ether 00:07:43:31:ba:40
        hwaddr 00:07:43:31:ba:40
        inet 192.168.100.56 netmask 0xffffff00 broadcast 192.168.100.255
        media: Ethernet 10Gbase-SR <full-duplex,rxpause,txpause>
        status: active
cxl1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: 10gb/s - 850nm
        options=ec07bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        ether 00:07:43:31:ba:48
        hwaddr 00:07:43:31:ba:48
        media: Ethernet none
        status: no carrier
em1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 0c:c4:7a:4d:0a:62
        hwaddr 0c:c4:7a:4d:0a:62
        nd6 options=1<PERFORMNUD>
        status: no carrier
        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
        groups: lo
        ether 02:72:64:4a:1f:00
That's from the FreeNAS host...
If you do iocage exec <jaliname> ifconfig you will get a different output. (replace <jailname> with the name of the jail.
urobe
I see, thanks for the clarification. The problem is, that the jail isn't created. The installation process stops with the error above.
urobe
I also tried to use dhcp instead of nat, I also tried to assign an ip manually, but also with no luck.
urobe
If I select dhcp instead of nat, I get the following error:
embyjail had a failure Exception: RuntimeError Message: + Acquiring DHCP address: FAILED, address received: 0.0.0.0/8 Stopped embyjail due to DHCP failure Partial plugin destroyed
If i only select vnet and assign an IP manually, I get the same error as in the first post.
urobe
It actaully just installed, with neither of dhcp, nat, vnet cheked, blank ip4 adapter and a manual ip address. However the service is not reachable.
This is the output:
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@nas[~]# iocage exec embyjail ifconfig
        description: em0
        status: no carrier
        inet 192.168.100.33 netmask 0xffffff00 broadcast 192.168.100.255
        status: active
        status: no carrier
        status: no carrier
        groups: lo
        groups: bridge
How were you trying to reach it? with no networking, the jail will have no target for you to reach.
what does iocage list show?
Have you tried an install with VNET, DHCP and BPF on?
Are you setting a gateway for the jail? Have you configured a gateway for your FreeNAS box in the Network settings?
urobe
when I manually asign an IP, it can't be reached.
I have tried it with BPF on, with one of them it is even an requirement. but still no success.
what i did now, is using a physical network card and not share the one the system uses. Now it works like it's supposed, but that shouldn't be the goal. with manual setup I have set the gateway (edgerouter), in the system the router is also set. I also tried to set the DHCPs server address (Windows server) in the jail, but it didn't help either.
Will try iocage list when I get home.
Thank you very much for your patience and help!
nikkon
same problem here. i tried all possible combinations and doesn't work. If I install a simple jail...all works
Ofloo
Same issue here, but i have to say I have precautions in place for clients trying to connect to DNS servers directly and not use the provided dns servers. But then my question is why does TrueNAS believes it should by pass the configured DNS servers ! This should never be a requirement !
It should respect the setup DNS servers and not do it's own thing. Just because it believes this is what it should do ! Actually it's iocage but anyway.
Disabling those rules makes the upgrade work!! Any client or service should always respect the configured DNS servers and not just do it's own thing.
To be honest I get suspicious of things like this. Why would you try and bypass the configured network setup.
