I am in the process of searching for a NAS solution for a small business. We currently use QNAP appliances, which have worked so far…there is need for a new device now though which needs to be encrypted and the QNAP solutions either don't have the right hardware to do that (no AES-NI, too slow) or are way too expensive for what they offer.
I started reading the FreeNAS forums and this seems to be the perfect solution for us. I am currently searching for some kind of minimal (although sufficient) hardware advice for a system with the following requirements: encrypted file systems, approx. 4x3TB disks, no other tasks except file storage (no transcoding etc.), can produce encrypted backups to another device (duplicity would be excellent)
I saw the Fracta Design Node 304 case, this seems to be very interesting for what we want to do…this would mean a mini-ITX board is needed.
From other threads it seemed that using an
ASRock E3C226D2I with an Intel i3 (for AES-NI)
or an
Avaton C2550
might be a good solution.
Are there other options that would be more suited to the task (also non ITX if better)? What performance impact can i expect for accessing encrypted shares via CIFS (the QNAPs drop by 50-70%, with AES-NI this should be much less, right?). What options do I have for encrypted backups using FreeNAS?
Any help would be greatly appreciated.
Many thanks
or an
Avaton C2550
Many thanks
