Why don't you just do a massive brain-dump of everything you know about esxi in a separate thread? Put a sticky in the "off-topic". :DWhich Joe are you referring to?
Just to see if FreeNAS will boot from a USB Flash drive or SATA drive? I believe there is one user running FreeNAS on this board but booted it from SATA.In my case basic functionality test would be sufficient
iKVM is still Java based and I cannot use the Virtual Storage, so I cannot mount an iso image. Maybe I'm doing something wrong, I'm not sure. I am reading the manual but no luck. My OS is Win 7 and I of course have the latest version of Java. I had to set the IMPI software to run as administrator to get the iKVM screen to work. Eh, more to play with soon. There is a firmware upgrade to which I'll do in a few minutes, one I read all the instruction on how to do it safely.
Boot/detect from passed-through SATA ports - i.e. verify that SATA pass-through will work (whole controller level)Just to see if FreeNAS will boot from a USB Flash drive or SATA drive? I believe there is one user running FreeNAS on this board but booted it from SATA.
I will hopefully be able to test this on the weekend where the onboard SATA controllers will pass through for ESXi.Boot/detect from passed-through SATA ports - i.e. verify that SATA pass-through will work (whole controller level)
Another gotcha I discovered was that the onboard graphics needs to be enabled for the applet to receive any video output. I had disabled it to use a graphics card to setup the BIOS and did not re-enable it afterewards. Took me an hour or so to find a forum post somewhere which explained the issue.
I seem to be able to access the IPMI even from other network ports which kind of surprises me. Is there some way to disable this?
@Graphics - Onboard graphics as in Processor graphics or onboard VGA? The latter is expected (because that is handled by the same chip that does IPMI), the former would be an issue since atm the processor graphics seem to cause FreeBSD to hang ie should be disabled.
@IPMI: There should be a bios option to disable IPMI sharing - at least if you have a dedicated interface for it. If its shared then hopefully there is an option to only share it with the single interface and not all of them... But that would be something to ask the vendor for-
How about getting a proper KVM over IP switch?;)
