crazychimpjimb
- Feb 2, 2022
Hello
Query to you very knowledgeable people. Im looking to build a NAS based on a mITX board in a small case so that I can fit it onto a shelve under the stairs out the way. I only use this as a NAS and SMB for file storage. I might look at remote access at a later date but I've never seen my 8th gen i7 run at more than 5%, The 32gb of RAM however thats a different story hahah.
So First question is for simple SMB storage on a mirrored setup i5 vs i7 is there a massive difference that I've over looked?
Second why did i mention i5 well Im struggling to find a mITX board for 8th gen so may need to buy into 10th or 11th gen as that's readily available.
Space is the main reason at the moment as if I had the space I would be using a Full Tower, room for expansion for more drives etc but sff is key for this build.
If your interested my build is a Lian Li q58 case, 400w SFX power supply, mITX board?, Processor unknown pending wise wisdom?, 2x 5TB 2.5hdd Seagate Barracuda (extra £10 in the UK each over the 4TB solution), Ram 32GB unknown what at the moment and finally using the 1 PCIe slot a 10GB Asus XG-C100C card for faster connectivity. The case I will hands up say I saw it on face book for £30 as the mesh panels had damage and couldn't turn that offer down!
Any advice in the right direction will be amazing :)
James
James
