I was on here I believe some time last year with the idea of turning a Node 304 into a FreeNAS system. It was more of a challenge than I thought but beyond that, other life events took over. I'd like to revive my idea of building a FreeNAS system, but using my existing HTPC system instead of the mITX box.
My current setup is as follows:
All parts are a little over 2 years old.
I'd like to convert the system to an ECC supported system. Only thing I see that's salvageable would be the PS.
How would this work from a hardware perspective?
Supermicro MBD-X9SCM
Xeon E3-1230v3 Quad Core 85W
Kingston ValueRAM 8GB DDR3 PC8 12800 (x2)
The other piece to this is that I will need to turn the small 304 mITX box into our HTPC. I'll drop the Caviar Blue drives in the HTPC. I'd like to reuse the Sandy Bridge CPU in the small HTPC if at all possible. I think I'd just need to replace the motherboard but be able to repurpose the RAM and CPU. I have a small 400W Antec PS I can use for the mITX. Thoughts on the board?
Gigabyte H77N LGA1155 mITX Board
General thoughts on the proposed build(s)? I think it'll maximize what I already have while minimizing waste. My current mobo would be the only component that wouldn't be re utilized. Thanks!
OCZ ModXStream Pro 500W
ASRock Z68 PRO3 GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W
4 x WD 500 GB Caviar Blue HDs
3 x WS 3 TB Caviar Red HDs (not all 7 HDs are in use, picked some up scrapping PCs at work)
G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
Fractal Design Arc Midi Black ATX Mid Tower
