Hello all,
My FreeNAS system was working fine until last week. Long story short, it appears my board (ASROCK C2750D4i) has died (among with a lot of other ones).
I've started looking at a replacement (motherboard & CPU), but haven't had a lot of luck finding an apt one.
I have the following constraints to work with:
Or has that ASROCK board been updated since, and would the new updated version be trustworthy again?
Many thanks
- Motherboard
- Mini ITX form factor
 - Minimum of 8 SATA ports : 6 SATA2, 2 SATA3 preferably (all SATA3 is fine as well - 2 is minimum)
 - 4 DDR3L RAM slots (1.35V - have 2x KVR16LE11/8 and 2x KVR16LE11L/8 : so a minimum of 32 GB)
 - IPMI support
 - >=1 LAN port (don't care for dual)
 - >=1 PCIE slot (slot for an MSATA adapter for SSD boot drive)
 - >=1 USB port (2 or 3, more don't matter)
- CPU
- Workload - smallish SOHO server, most intensive will be transcoding a max of 4 full HD streams
 - A small TDP (450W power supply & most of the time will be spent idle), passive cooling is preferred (but active won't be a dealbreaker)
 - ECC RAM support (Kingston!)
 - Virtualization support (looking at FreeNAS 10)
Many thanks
