My NAS Asrock C2550D4I mini ITX motherboard just died, so I am looking for a replacement recommendation.
Ideally I would like to keep everything else, so I would like a motherboard in mini ITX factor that could use the 64GB of DDR3 UDIMM ECC RAM I have there, should have 6 SATA3 ports, should have some iKVM/IPMI and (if possible) fanless CPU, or one with very small and silent fan. If keeping the RAM would limit my options excluding some awesome motherboard, then I would be willing to give it up and buy new ECC RAM if needed.
What's out there that you would recommend? Thanks in advance!
