ASRock H170M-ITX/ac Supports ECC, Operates in Non-ECC Mode
Steve Salier
I am looking to build a FreeNAS server. One of the potential builds I am looking at uses an ASRock H170M-ITX/ac motherboard. Under the specifications for the RAM (http://www.asrock.com/mb/Intel/H170M-ITXac/?cat=Specifications), it claims "Supports ECC UDIMM memory modules (operate in non-ECC mode)". I was wondering if this would be suitable to use in a FreeNAS server, or if it would be no different than running FreeNAS on non-ECC RAM.
Also, I would love to hear any other recommendations for a Mini-ITX motherboard. FreeNAS will be a VM running on a Citrix XenServer hypervisor alongside other networking-centric VMs. ECC support is obviously a need. Preferably, the board should also support M.2 and integrated graphics, though both are optional.
Thank you very much for your time!
Probably a bit overkill on the CPU side - but this is a seriously beefy 64GB system ....
Board:
ASRock EPC612D4I miniITX LGA 2011 R3
$269.99
http://www.asrockrack.com/general/productdetail.asp?Model=EPC612D4I#Manual
RAM:
4 x Transcend 16GB ECC DDR4-2133Mhz 1.2v Unbuffered SO-DIMM (260-pin)
https://www.cdw.com/shop/products/Transcend-DDR4-16-GB-SO-DIMM-260-pin/3819776.aspx
$152.00/each
CPU:
Intel Xeon E5-2620 v3 Haswell 2.4 GHz (6 core/12 threads, 15ML L3 cache) LGA 2011-3 (85W)
http://ark.intel.com/products/83352/Intel-Xeon-Processor-E5-2620-v3-15M-Cache-2_40-GHz
$429.99
Heatsink/Fan (narrow ILM):
http://www.dynatron-corp.com/en/product_detail_1.aspx?cv=&id=260&in=0
$30
