Fresh install of 9.10. Have the issue of the jails not getting the IP addresses from the DHCP in my router unless I did a full reboot of the FreeNAS server. (That included also manually adding an entry into the DHCP Reservation Table using the MAC address of each jail...) Thing were working nicely. The past few days there had been a few moments of laggieness, but didn't really put too much into it... This morning, everything was working fine. Took my better half to work, came home and all of a sudden my Sickrage plugin isn't responding...
I take a look into it only to realize that the service had shut itself off. I try to restart it via Plugins > Installed and I keep getting the msg "Apr 11 16:42:40 freenas manage.py: [plugins.utils:91] Couldn't retrieve
http://192.168.xxx.xxx/plugins/sickrage/5/_s/ JSON object could not be decoded". I checked to see if there was an update, there was, and I updated to the latest, version is in my sig...
I have manually restarted the jail via Jails > Jails (yellow happy face looking button at bottom) and it restarts without error and shows the proper IP address for the jail in the table.
I tried executing "service sickrage onestart" and I get the following results:
 Starting sickrage.
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/SickBeard.py", line 564, in <module>
    SickRage().start()
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/SickBeard.py", line 313, in start
    sickbeard.initialize(consoleLogging=self.console_logging)
  File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/__init__.py", line 799, in initialize
    gettext.translation('messages', 'locale', languages=[GUI_LANG], codeset='UTF-8').install(unicode=1)
  File "/usr/pbi/sickrage-amd64/lib/python2.7/gettext.py", line 469, in translation
    raise IOError(ENOENT, 'No translation file found for domain', domain)
IOError: [Errno 2] No translation file found for domain: 'messages'
/usr/local/etc/rc.d/sickrage: WARNING: failed to start sickrage
All my other jails are running fine with no issues, which include transmission, syncthing, plexmediaserver and couchpotato. It's only sickrage that's having the issues...
