Sokonomi
- Jul 15, 2018
Hi all,
I'm having a weird bug where it wont let me add a mount point to my jail.
The destination path is '/mnt/Tank1/Cloud/Private/Home Media/' but it wont accept it, saying 'File name too long'.
Detail print from the popup;
I'm not sure what the problem is, but both paths exist.
I'm guessing it doesn't like to have spaces in the path? (this is a problem)
I'm using FreeNAS 11.2-Beta2
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 662, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 389, in fstab
dump, _pass, index=index)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/iocage.py", line 1005, in fstab
exit_on_error=self.exit_on_error)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fstab.py", line 65, in __init__
self.__fstab_parse__()
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fstab.py", line 83, in __fstab_parse__
self.__fstab_mount__()
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fstab.py", line 165, in __fstab_mount__
raise RuntimeError(f"{stderr_data.decode('utf-8')}")
RuntimeError: mount: /mnt/Tank1/Cloud/Private/Home Media: File name too long
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 154, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/asyncio/coroutines.py", line 129, in throw
return self.gen.throw(type, value, traceback)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1013, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 950, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 977, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 908, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 902, in run_in_executor
RuntimeError: mount: /mnt/Tank1/Cloud/Private/Home Media: File name too longI'm not sure what the problem is, but both paths exist.
