TW1920
- Jan 4, 2019
I'm using Plex on my FreeNAS - it worked well to my last restart of the NAS.
I mounted some Datasets on the jail (with command line on the jail) - it looks like the jail configuration have saved it but I get now these error starting the jail:
On the NAS I can access to /mnt/Storage_100101_z2cl/Dataset_100101_Media/Filme without any problem. So I looked to "Mount Points" of my Plex Jail - there are the Mount for "Filme" exists on 3 lines. Two like on the error message, on the other one the destination is "/mnt/Filme" - there was my mount point before restart. Why I have now 3 entries for one mount and 2 of them to the wrong destination?
Adding the mount again would be no problem, so my plan was to delete the mount points, but doing this I get this error:
How can I delete the wrong Mount Points?
Now I know it's not good to mount something on a jail, but I have no plan I can fix that. Searching for that I couldn't find something useful.
Thanks
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 581, in start
iocage.start()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1663, in start
callback=self.callback
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__
self.__start_jail__()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 401, in __start_jail__
silent=self.silent)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 90, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
RuntimeError: mount: /mnt/Storage_100101_z2cl/Dataset_100101_Media/Filme: No such file or directory
jail: /sbin/mount -t zfs -o rw /mnt/Storage_100101_z2cl/Dataset_100101_Media/Filme /mnt/Storage_100101_z2cl/iocage/jails/plex/root/mnt/Filme: failed
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 165, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1141, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1078, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1105, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1036, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1021, in run_in_executor
jail: /sbin/mount -t zfs -o rw /mnt/Storage_100101_z2cl/Dataset_100101_Media/Filme /mnt/Storage_100101_z2cl/iocage/jails/plex/root/mnt/Filme: failedOn the NAS I can access to /mnt/Storage_100101_z2cl/Dataset_100101_Media/Filme without any problem. So I looked to "Mount Points" of my Plex Jail - there are the Mount for "Filme" exists on 3 lines. Two like on the error message, on the other one the destination is "/mnt/Filme" - there was my mount point before restart. Why I have now 3 entries for one mount and 2 of them to the wrong destination?
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 684, in fstab
dump, _pass, index=index
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1037, in fstab
index=index
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_fstab.py", line 67, in __init__
self.dests = self.__validate_fstab__(self.fstab, 'all')
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_fstab.py", line 194, in __validate_fstab__
exception=iocage_lib.ioc_exceptions.ValidationFailed
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_exceptions.py", line 32, in __init__
collections.Iterable
NameError: name 'collections' is not defined
job,
Thanks
