Trying to mount storage for a jail, keeps erroring
fmdx
Currently trying to mount storage for a jail, and it keeps error'ing out through the FN GUI:
(I've modified the outputs to say <directory>)
RuntimeError
mount: /mnt/Volume1/<directory>/<directory>: Operation not supported by device jail: /sbin/mount -t None -o rw /mnt/Volume1/<directory>/<directory> /mnt/Volume1/iocage/jails/sabnzbdtest/root/mnt: failed
More info states:
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 541, in start
iocage.start()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1628, in start
callback=self.callback
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__
self.__start_jail__()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 413, in __start_jail__
silent=self.silent)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 81, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
RuntimeError: mount: /mnt/Volume1/<directory>/<directory>: Operation not supported by device
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1043, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 980, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1007, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 938, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 923, in run_in_executor
diskdiddler
What exact paths are you mounting?
fmdx
mount: /mnt/Volume1/Personal/MediaLibrary: Operation not supported by device jail: /sbin/mount -t None -o rw /mnt/Volume1/Personal/MediaLibrary /mnt/Volume1/iocage/jails/sabnzbdtest/root/mnt: failed
akira997
Just came across the same thing, but I cannot wait. If you also can't simply edit:
with the changes mentioned in: https://github.com/freenas/freenas/...0bb17ef#diff-733632ed3837168816d4101e2fbafafa
edit from (Line 566):
Str("fstype"),
Str("fsoptions"),
Str("dump"),
Str("pass")
to:
Str("fstype", default='nullfs'),
Str("fsoptions", default='ro'),
Str("dump", default='0'),
Str("pass", default='0'),
No need to restart. Just recreate the mountpoint and start the Jail.
